P195 15 R75 Tires
  • P195 15 R75 Tires
    Since all my references are packed up in
    boxes in preparing to move....again. Can
    someone refresh my "brain" what the proper
    PSI is for my 1953 Sedan....I would check
    the side walls for the max...but since I
    have the wide whites showing, the psi info
    is on the inside naturally.
    Thanks
    Glen Brose
    Chino Valley, AZ
    Home of "Charlene"
    53 Champion Tudr Sedan
    I run my '53 coupe with bias ply tires at 32 lbs front and 29 lbs rear. If they are the same front and back it becomes squirly.
    Tom Bredehoft
    '53 Commander Coupe
    '60 Lark VI
    '05 Legacy Ltd Wagon
    All three Indiana built cars
      Thanks Tom! I appreciate it and the
      little extra info, as well!!!
      Glen Brose
      Chino Valley, AZ
      Home of "Charlene"
        The 1953 Champion owner's manual calls for 26 front and 24 rear for the stock 6.40 x 15 bias ply tires. With the radials, I'd be tempted to run higher pressures. I run 32 all around on my '54 with radials.
        Bellingham, WA
          Thanks Dick!!! I am thinking that the
          last real time I had them looked at
          a professionsal shop, they were set
          at 30 or 32. Can't go wrong with the
          32psi....I will experiment to see how
          they behave.
          Glen Brose
          Chino Valley, AZ
          Home of "Charlene"
            Commonly, the car maker specifies lower pressure to get softer ride and the tyre maker calls for a bit higher pressure to get longer tyre life. Keep an eye on the wear pattern on your tyres - too much pressure and you get more wear in the centre, too little and the edges wear quicker.
            /H
              Thanks Hank, appreciate the imput!!!
              Have a good day...down under!!! [8D]
              Glen Brose
              Chino Valley, AZ
              Home of "Charlene"
