Ring Specs
  • Ring Specs
    What are the specs on the rings in a Studebaker V-8? I'm not asking about the diameter but the thickness of each ring in order to give the correct information to Total Seal so I'll get the right stuff. Thanks,
    Darryl C. Lewallen Clarkesville, Ga.
    Darryl, I am thinking you would have to contact a Piston Ring manufacturer technical Dept. that makes Stude. rings like Grant, etc. for those, since Studebaker would have no need to mention the thickness, since all 3 9/16" Std. or oversize ring sets are made to fit all 1955-64 Stude. V-8's except '64 Avanti & Jet Thrust 304.5
    R3 & R4. and you just order them. I understand why you need it, but I checked Grant's site with no luck, you need to call.
    Rich.
    Studebakers Northwest
    Ferndale, WA
      5/64", 5/64" , 3/16"
        Thank you,
          Carefull on dimensions.....depends on the piston design.
          Could go either way!
          Mine are 1/16", 1/16", 3/16".
