Modified Hydrovac for dual master cylinder
  • Modified Hydrovac for dual master cylinder
    There are a couple of threads concerning hydrovac booster units and the good and bad issues, etc. One of the issues that always comes up is that the Studebaker and all other hyrovacs applications I am aware of can only be used with a single chamber master cylinder. Well ECI has a fix, looks like two hydrovacs back to back, also it can be powered by a electric vacuum pump. Not cheap but it is a fix!
    http://www.ecihotrodbrakes.com/remote_booster.html
    Dan White
    64 R1 GT
    64 R2 GT
    The guy with that dual turbo'd bright red SBC Pro Street Avanti II that was at the drags at South Bend '02 had a dual hydrovac setup like the one you described...mounted in the tunk!
    Dan White
    DEEPNHOCK at Cox.net
    Ocala, FL.[u](For one more month!)</u>
    '61 Hawk (project)
      It would probably have to go in the trunk. It would not fit in the usual spot under the hood too well (if at all).
