Brake cylinder goo
  • Brake cylinder goo
    I'm replacing the brakes(lining,cylinders,hoses). I notice a varnish goo inside the rubber covers of the brake cylinders. Is this dried DOT3? Do come folks put grease inside the outer rubber covers of the wheel cylinders??
    The goo is a mixture of brake fluid, water and dirt . And corrosion of the various insides of the brake components.
    Clean it all out and rebuild the cylinders.
      I put a little silicone grease on the lips of the cups when I rebuild wheel cylinders; I don't know if it helps or not but it sure does make them go together easier and it makes me feel like I'm doing something useful
        NAPA carries honest-to-gosh "Brake Assembly Lube" I've used it for years. I used to use the Girling brake assy grease that was supplied free in their repair kits, but I finally used all of the little tubes I had saved from the good ol' days so I turned to the NAPA stuff. McKay makes it too. I don't know if that brand is universally prevealant across the US but it's common out here.
        Seems to be glycerin based. I don't really know for sure but I like using it. (on the brakes, of course!)
        When I was into rubber-powered free flight models, we used a green soap and glycerin mixture to lube the multi-stranded rubber motors. It made the rubber less likely to cut into itself when wound to the max. Less chance of knots developing as well.
        You remember that ol' Green Soap from school days, right?[^]
          Don't forget the DOT 5 brake fluid![8D]
