tachometere woes
  • tachometere woes
    All-
    I have a VDO lo-rev tachometer, 0-4K. I hook it up and the most it will read like 200 rpm. Even revved. It's erratic and I wonder if something may be amiss in the distributor?
    I have hooked up a tach before and it too was erratic.
    The one I have is a VDO 12V/700-1300 Hz...
    dan
    Stuff:
    1941 M15...retirement project
    1953 2R11...daily ride
    2001 F-350 Super Duty Lariat to haul it all..
    1989 Caprice Classic Brougham
    Two sexy Deere's: 112H/332
    Dan-o,
    Some aftermarket tachs have a switch located somewhere on the case of the unit. It may have 3 positions...4-6-8 for the # of cylinders your engine has. Safe to assume your vehicle is 12V. Hope this helps.
    Dan
      All-
      If I were to purchase a tach; what range should I consider for the Commander 6 engine?
      I'm thinkin 0-3K??
      yes/no?
      dan0
      Stuff:
        I also have a problem with a VDO tach. I spoke with the vendor I purchased it from. He recommended a tach filter. In doing some research, I found a couple solutions.
        On the VDO page, www.sso-usa.com/performance they have a tech support section. Here they list a tech bulletin for tachs. It tells you how to build a filter for a couple of bucks.
        www.Classicinstruments.com list a tach filter #SN20.
        I got a SN20, but have not tried it yet. I will let you know.
          Thump-
          The VDO I found on ebay was for a tach-gen setup, my bad. I seek some of the smaller gauges like the Stewart-Warner 1-1/2" ones so they will not hog the dash up..hard to locate a matching set!
          dan0
          Stuff:
