transmission oil
  • transmission oil
    I want to change the oil in the transmission for my 63 Lark 3speed w/o overdrive. I understand I should use SAE80 gear oil which I can't find. Is SAE40 motor oil a substitute? Or SAE80/95 which is readily available. Also, any ideas why I occasionally have a hard time shifting into 2nd. Seems if I fiddle with the lever a bit, I can get it in gear. This only happens once in awhile and I haven't noticed any pattern.
    Thanks!
    Terry
    You can use GL-5 or you could use a synthetic. I know Redline and Amsoil have synthetics that work. The 2nd shift problem sounds like linkage misadjustment and not tranny problems.
    What shape are the engine mounts in? soggy or broken motor mounts can cause problems as they throw the shifrt linkages out of alignment[xx(]
      Terry - I have 3 Studebakers with 3-spd transmissions with overdrive. I have used AmsOil 75W90 synthetic gear oil in these for over 20 years without a problem. They shift well in the cold weather and the bearings last a long, long time.
      Seems like whenever I had difficulty shifting (previous Stude, not my current ones), it was always 2nd gear. Maybe the synchronizing ring for 2nd wears out faster. A work around that helps is to pull the lever into high before putting it in 2nd. The synchro ring for high slows the spinning gears a bit allowing it to more easily shift into 2nd. Since yours is only occassionally balking, you probably only need to do this when you encounter the shifting problem. Like I said, this is just a work around. It will reduce your frustration level and help you get by until you fix the problem.
      Dale
        I like Redline MT-90; it's GL-4 rated so it won't attack yellow metals and really does make for slicker shifting, and seems to extend the life of worn synchros. However my only experiences with it have been in VW's and T-10s, I have not tried it in a 3/OD, so I don't know if the OD section would still work properly. ISTR that the OD section requires a 40W mineral oil? check your shop manual, anyway...
        62 Daytona hardtop
          I had almost the same shifting problem going into Reverse (Although my '51 is an automatic). I'd fiddle with the shift lever in Reverse, Stella would think about it, THEN start going backwards. Changing the rear motor (transmission) mounts solved the problem. Maybe it's the same for a 3-speed.
          Boy, that was fun.[xx(]
          1951 Commander Starlight Coupe (aka "Stella")
          www.bulletshots.net
          www.bulletshots.net/blog
          www.alabamastudes.com
            It's easier for the standard shift, Eric
              Thanks!
              Terry
              I'm still dubious about using synthetics in overdrives. Everything I have read says to use only MINERAL oil. Don't use gear oil with additives or detergent motor oil. 40 weight NON-DETERGENT oil is an acceptable substitute for the 80 mineral gear oil. You can usually find either at farm stores such as Tractor Supply. My '64 Daytona Wagonaire which I have owned since new is overdrive equipped. Some years ago I added off-the-shelf 80-90 gear oil and shortly thereafter the overdrive quit working internally. I understand that the overdrive needs some friction to operate properly.
              Paul Johnson
              Museum R-4 engine
                In my ignorance (OK, it's really laziness[xx(]) I've pumped GL-5 in the tranny, OD section and rear axle of this Transtar I flail with disrespect. It doesn't seem to care.
                I've got a rebuilt 289 sitting on a stand out in the shop that's slated to go into this truck. I want to do it up right with a freshened T-85, since this one leaves it's GL-5 wherever I park it.
                For now tho, I can't afford to put it down. Once this Provincial is roadworthy, the Transtar will get it's rehabbing.
                I was bombing around town in it today and it occured to me how mindlessly I drive that truck. I rarely give thought to whether or not I need to use the clutch to shift it when it's under 30MPH. There's some subliminal conversation or cognizance of whether it's in or out of OD as I manuver around town.
                I stopped at a plumbing supply and I didn't give it a thought that the Transtar could be a celebrity (although it's always reminding me). My mind was on the pipe I was in need of.
                In checking out, the gal working the register had to comment on my "pretty truck". She wasn't even aware it was a Studebaker until I said so. That really wowed her (hey - she had to be about my age!). She mused as to how doubly special that must make it.
                At another place I went, I parked in a lot with a dufus security guard. He said nothing as I exited the truck and went into the shopping area. But an hour later, when I returned to the truck, he hailed me. He said: "That's one cool truck. You wouldn't believe how many folks have stopped to look at it and comment since you parked it."
                Honestly, I just drive this thing. It's all I HAVE do drive at the moment! It's transport from point A to point B. And yet, it causes smiles and memories wherever I happen to park it.
                  Is anyone here starting to get the impression Bob likes Studebakers?
                    It's almost enough to make one a little misty
                    Dan
                      Hey. It IS one cool truck<G>.
                      Paul Johnson
                      Museum R-4 engine
                        The real wierd thing is that Bob actually looks GOOD in that truck. [8D]
                        (must be the truck )
                        Bellingham, WA
                          Don't know where I remember reading this...maybe in the Co-operator, but I've been using a GL-1 rated oil in all my Stude's 3-speed ODs with great results, and the 5 gallon bucket is easily ordered from NAPA. I use a pump with the long, clear hose since I have to crawl under.
                            Today, I was at a Tractor Supply Co. store, and they have 2-gal containers of both the lubricants recommended in the Borg Warner overdrive manual:
                            1) 40w non-detergent motor oil (approx $16, the BW preference)
                            2) 90w straight mineral oil (approx $24, for hard conditions)
                            As someone in this forum pointed to in a similar thread months ago, here's a link to the page in that OD manual. The recommended oils are in the last paragraph:
                            http://www.tocmp.com/manuals/trans/B...age_19_jpg.htm
                            And if you want the entire overdrive service manual OR instruction manual, in SEARCHABLE pdf format, I have made them available for download here:
                            http://rocketdillo.com/studebaker/mi...iveManuals.asp
                            [img=left]http://rocketdillo.com/studebaker/misc/images/Current_Avacar.gif[/img=left] - DilloCrafter
                            1955 1/2 Ton Pickup
                            The Red-Headed Amazon
                            Paul Simpson
                            "DilloCrafter"
                            1955 1/2 Ton Pickup
                            Deep in the heart of Texas
                              I purchased a 5 gal bucket of Chevron SAE 90 gear oil with GL-1 rating from Dick's buddy here in the beautiful Pacific Northwest. It's been in all my standard trans Studebakers for many years.
                              Brian
                              Brian K. Curtis
