6 vplt to 12 volt inverter
  • 6 vplt to 12 volt inverter
    Did someone recently post a URL for a site that sold 6 volt to 12 volt inverters?
    thx
    Try jc whitney? They have a searchable website,but at quick glance I didn't see any 6-12 volt inverters.I know little about electrical,can 12 be had from 6?? I know there are reducers for say,12 volt to 6 volt..
    LaSalle,Il
    61Hawk
    60Lark
    Oglesby,Il.
      I don't know about 6 to 12 volt inverters, but if you go to this website:
      http://www.reconnsworld.com/power_voltdoubler.html
      you can get a schematic for a voltage doubler using an IC555 timer that can be used to power low amperage 12 volt stuff in your 6 volt car. Unfortunately, it won't work for the magnetic clutch on an air conditioner compressor. It can be used for things like an electric fuel pump or a fan in the air conditioner or heater. Or you could run your cell phone charger. What are you planning?
        Hi 55 prez
        Try www.powerstream/dc6-12.htm
        They have invertors up to 15 amps and 30 amps. 150 watts.
        Probably run what you want .
        Starlightchamp
        50 starlight
        63 hawk
        The 1950 Champion Starlight
        Santa Barbara
        CA
          Here are a couple more sources for inverters:
          http://www.antiqueautomobileradio.com/productsF.htm
          http://www.pressenter.com/~cmeyer/index.html
          Gary Ash
          Dartmouth, MA
          '48 M5
          '65 Wagonaire Commander
          '63 Wagonaire Standard
          www.studegarage.com
          Gary Ash
          Dartmouth, Mass.
          ’41 Commander Land Cruiser
          '48 M5
            Thanks to all for the responses. I'm going to fit a 12V radio/cdplayer to the 55 for long distance tunes
            64 GT Hawk (K7)
            1970 Avanti (R3)
              For that application, you will want an inverter/converter. Remember, besides going from 6 volt to 12 volt, you also want to go from positive ground to negative ground. I have one here that I used in a '53 in the '70s (for a 5 watt cb radio). I paid $35 for it then and would sell it for that much now (plus shipping). It is an E. F. Johnson Co. unit, P/N 239-0120-002 and it is Made in USA. I mounted it up behind the dash, out of sight. Maybe you can find something locally, or cheaper, to do what you want.
              1959 DeLuxe pickup (restomod)
                Gary,
                If 55Prez does not want to buy your converter, I will buy it.
                Studebaker Fever
                60 Lark
                51 Champion
                Phil
                Studebaker Fever
                60 Lark
                56 Power Hawk
                Phil Hendrickson
                Arnold, Missouri
                  I'll be taking Gary up on his offer.... :-)
                  64 GT Hawk (K7)
                  1970 Avanti (R3)
                    I'd like to take Gary up on his offer ... :-) thanks
                    64 GT Hawk (K7)
                    1970 Avanti (R3)
                      Invertor and converter combos are not easy to come by from my past experience.
