See more
See less
Battery for '52 2R16 Tractor battery? Which one??
  • studeclunker
    Folks, you forget that California is the home turf of the eco-nazi. These people have so many requriements and recovery taxes that everything is more expensive here. It's getting rediculous. I'm not surprised that batteries are twice as expensive at the bargin prices here. They even want to charge us sales tax for our purchases OUTSIDE California! They call it a use tax.
    Welcome to the People's Republic Of California. Only, the big lie is; it's not run for the people.
    Home of the famous Mr. Ed!
    Lotsa Larks!
    Ron Smith
  • 60Lark
    TSC in my area is Tractor Supply Co., and they do sell batteries for tractors and farm equipment, but to be honest, I had never thought about looking there for a battery for my cars
    Studebaker Fever
    60 Lark
    51 Champion
    Phil
    Arnold, Missouri
    Kent is TSC a local small Mich. batt. manufacturer, that non-locals cannot get or what? That's one heck of a good Batt.(820 AMPs WOW!) AND price![^] I would recommend it to West Coast people, IF we could get one!
    Studebakers Northwest
    Ferndale, WA
  • 54-61-62
    I just went and looked my $38 TSC battery, it has 820 amps. That particular battery has started a big old 1947 Minneapolis-Moline "U" for years, anyone who has farm experience will recognize that the U is a massive chunk of iron to turn over and start.
    If it will start that MM U it will certianly crank over a Stude truck.
    Kent
  • JDP
    A 8 volt is a drop in and only usually requires a regulator adjustment, it 'might' lessen bulb life a bit, but that's it. Battery Warehouse sells them around here.
    64 Commander 2 dr.
    64 GT Hawk R2 clone
    64 Daytona HT
    63 R2 4 speed GT Hawk
    63 Avanti R1
    63 Daytona convert
    63 Lark 2 door
    63 Lark 2 door #2
    62 Lark 2 door
    60 Lark HT
    60 Hawk
    59 3E truck
    52 Starliner
    51 Commander
    Ron; it's all about the Cranking AMPs CA , and [u]Cold</u> Cranking AMPs CCA! Very important, don't be misled by PRICE unless it has the same or more POWER, if that farm tractor batt. for $38.00 has 730 AMPs or more(like the NAPA one) it's a real deal, it not it isn't.! Most Group 1 batt. are sold for little 4 cyl. VW's and have a low cranking AMP rating!
    Since you asked if it was 6 volt, I take it you are not too familiar with pre 1956 models, so I'll remind you: DON'T FORGET TO GROUND THE + BATT. POST!!!
    Ferndale, WA
  • 54-61-62
    I don't know about California prices, but here in Michigan at a Tractor Supply Store (chain farm store) I can get a 6V battery for $38. Other stores are not considerably higher.
    Kent
  • studeclunker
    I called two dealers of batteries (in Anderson, CA) and they both said the same thing about 8V batteries. 'Don't do it! It'll fry your electrical system! to put in an 8V battery the generator/alternator need to be changed and the voltage regulator will have to be changed as well.'
    Miller Equipment in Anderson has the 6V battery for less than sixty dollars. So, looks like I'm in business. I just might get two, just in case. Hmmm, I'm going to need a charger too, as my current one is 12V.
    When one is ignorant like me, it's best to play it safe. However, if anyone would care to educate me on the 8V, I'm willing to listen. Spin faster, start easier, good! Yep, yep, yep! Spin faster, start easier, fry electrical, Bad! Nope, nope, nope![V]
    Thanks for the help!
    Lotsa Larks!
    Ron Smith
  • studeclunker
    Kent,
    THANK YOU!!
    I'll call on that in the morning.
    Lotsa Larks!
    Ron Smith
  • 54-61-62
    Ron,
    Go get yourself a battery from a farm store, six volt for a Ford 8N tractor; its the correct size for the six volt trucks.
    I used to have several C-cab trucks, and I remember pilligaing the battery out of our Ford tractor and it fit "right" in the truck.
    Kent
  • Guido
    Ron,
    I have a '52 2R17A, but without looking in the parts book I suspect the battery tray was the same size as on all trucks. Unfortunately I do not have a truck here at my house that I can readily check. Perhaps someone can give you measurements.
    Gary
  • studeclunker
    Guido, don't you have one? The truck is about three or four hundred miles from my house. I'd like to try it this weekend and need to know what will turn it over. So, it's not like I can just pop down and check. Sorry about the bother, fellas, it's necessary to me to know if this thing will run. If not...[V] but if so...
    Lotsa Larks!
    Ron Smith
  • tbredehoft
    Optima Red Top 6 volt (880 CCA) will fit diagonally in a Group 1 case. (I think), I'll report in a week or so.
    [img=left]http://www.alink.com/personal/tbredehoft/Bothcars.jpg[/img=left]
    Tom Bredehoft
    '53 Commander Coupe
    '60 Lark VI
    '05 Legacy Ltd Wagon
    All three Indiana built OD cars
  • Guido
    Best thing to do would be to measure the tray and find the biggest battery that will fit in it.
  • studeclunker
    quote:As a '52 model, it would actually be a 2R16-A and have the 245 Commander motor. You may be better off going with an 8 volt tractor battery to give you extra starting capacity.
    Gary
    I've heard members mention that. The question is, again, which one?
    Lotsa Larks!
    Ron Smith
