Battery for '52 2R16 Tractor battery? Which one??
  • Battery for '52 2R16 Tractor battery? Which one??
    Which battery would I need for a '52 2R16? I assume (and we all know what THAT word stands for) the system would be 6 volt? I've been told a 'Group 1' and a '2EE'. But which is it?
    C'mon guys! I need your help here!![8]
    Home of the famous Mr. Ed!
    Lotsa Larks!
    Ron Smith
    Ron Smith
    If it's square and something like 9" X 8" X 7", then it's a group 1. Go to NAPA and ask for a USRN-1. It's a 100 amp hour, 730CCA. About $65.00
    Bob Johnstone
    64 GT Hawk (K7)
    1970 Avanti (R3)
      Clunk,
      As a '52 model, it would actually be a 2R16-A and have the 245 Commander motor. You may be better off going with an 8 volt tractor battery to give you extra starting capacity.
      Gary
        quote:As a '52 model, it would actually be a 2R16-A and have the 245 Commander motor. You may be better off going with an 8 volt tractor battery to give you extra starting capacity.
        Gary
        I've heard members mention that. The question is, again, which one?
        Lotsa Larks!
        Ron Smith
        Ron Smith
          Best thing to do would be to measure the tray and find the biggest battery that will fit in it.
            Optima Red Top 6 volt (880 CCA) will fit diagonally in a Group 1 case. (I think), I'll report in a week or so.
            Tom Bredehoft
            '53 Commander Coupe
            '60 Lark VI
            '05 Legacy Ltd Wagon
              Guido, don't you have one? The truck is about three or four hundred miles from my house. I'd like to try it this weekend and need to know what will turn it over. So, it's not like I can just pop down and check. Sorry about the bother, fellas, it's necessary to me to know if this thing will run. If not...[V] but if so...
              Lotsa Larks!
              Ron Smith
              Ron Smith
                Ron,
                I have a '52 2R17A, but without looking in the parts book I suspect the battery tray was the same size as on all trucks. Unfortunately I do not have a truck here at my house that I can readily check. Perhaps someone can give you measurements.
                Gary
                  Ron,
                  Go get yourself a battery from a farm store, six volt for a Ford 8N tractor; its the correct size for the six volt trucks.
                  I used to have several C-cab trucks, and I remember pilligaing the battery out of our Ford tractor and it fit "right" in the truck.
                  Kent
                    Kent,
                    THANK YOU!!
                    I'll call on that in the morning.
                    Lotsa Larks!
                    Ron Smith
                    Ron Smith
                      I called two dealers of batteries (in Anderson, CA) and they both said the same thing about 8V batteries. 'Don't do it! It'll fry your electrical system! to put in an 8V battery the generator/alternator need to be changed and the voltage regulator will have to be changed as well.'
                      Miller Equipment in Anderson has the 6V battery for less than sixty dollars. So, looks like I'm in business. I just might get two, just in case. Hmmm, I'm going to need a charger too, as my current one is 12V.
                      When one is ignorant like me, it's best to play it safe. However, if anyone would care to educate me on the 8V, I'm willing to listen. Spin faster, start easier, good! Yep, yep, yep! Spin faster, start easier, fry electrical, Bad! Nope, nope, nope![V]
                      Thanks for the help!
                      Lotsa Larks!
                      Ron Smith
                      Ron Smith
                        I don't know about California prices, but here in Michigan at a Tractor Supply Store (chain farm store) I can get a 6V battery for $38. Other stores are not considerably higher.
                        Kent
                          Ron; it's all about the Cranking AMPs CA , and [u]Cold</u> Cranking AMPs CCA! Very important, don't be misled by PRICE unless it has the same or more POWER, if that farm tractor batt. for $38.00 has 730 AMPs or more(like the NAPA one) it's a real deal, it not it isn't.! Most Group 1 batt. are sold for little 4 cyl. VW's and have a low cranking AMP rating!
                          Since you asked if it was 6 volt, I take it you are not too familiar with pre 1956 models, so I'll remind you: DON'T FORGET TO GROUND THE + BATT. POST!!!
                          Studebakers Northwest
                          Ferndale, WA
                            A 8 volt is a drop in and only usually requires a regulator adjustment, it 'might' lessen bulb life a bit, but that's it. Battery Warehouse sells them around here.
                            64 Commander 2 dr.
                            64 GT Hawk R2 clone
                            64 Daytona HT
                            63 R2 4 speed GT Hawk
                            63 Avanti R1
                            63 Daytona convert
                            63 Lark 2 door
                            63 Lark 2 door #2
                            62 Lark 2 door
                            60 Lark HT
                            60 Hawk
                            59 3E truck
                            52 Starliner
                            51 Commander
                            JDP Maryland
                              I just went and looked my $38 TSC battery, it has 820 amps. That particular battery has started a big old 1947 Minneapolis-Moline "U" for years, anyone who has farm experience will recognize that the U is a massive chunk of iron to turn over and start.
                              If it will start that MM U it will certianly crank over a Stude truck.
                              Kent
