I am having trouble with the overdrive. It freewheels as it should but when u get back in the gas it`s still the same, no change I`ve checked the wiring as shown in the manual. I ran a hot wire with a toggle switch to the silenoid. It clicks but still nothing happens. Is it possible for the silenoid to make a noise and still be bad? Thought about replacing it but can`t find one. any help or ideas on where to find one would be a help thanks
56 Champion overdrive won`t engage
Before you replace the solenoid (they're pretty stout) you might wiggle and inspect all the wiring as they do sometimes over the years get insulation rubbed off, so one might be grounding. Or one might be loose. I had a problem like this and took the relay off the firewall, gently removed the 'can' and cleaned the contacts with 1500 grit paper and that worked. Also sometimes the governor can foul if oil gets in and you can, under the car, take the top off and wipe things off in there. Hope this helps!
Running a wire to the solenoid wouldn't be right (in the traditional sense) if your '56 still has all it's components (solenoid AND relay). Of course, maybe you've chosen to run POWER to the solenoid as a means of control INSTEAD OF providing the power relay with a ground as the governor would do.
If you've done it like that (provided power directly to the solenoid), you're not gonna have a "kickdown" function even if you do manage to make the solenoid pull in.[B)]
1963 Daytona project FSNo deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
I like to set the lockout cable such that the handle is about 1/8" short of being bottomed out at the dash end when the OD shift lever is all the way back to the stop. That ensures that you can always get the lever into the "full on" position when you select OD by pushing in on the handle.
Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
Was the overdrive fused in 56 or was that only the later models. I know when my 63 would free-wheel and not engage it was usually the fuse."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
The 56s (57s too) had a fuse on the OD relay. 63s wouldn't have a relay, but it did have an inline fuse.
I just RE-read 56's post and he states he ran a "hot wire", which I guess would mean 12volts - and not a ground. Maybe, as Grodr says, it's a case of the cable not being ALL the way back. Be nice if it was that easy.
56, that fuse holder's a prime suspect (assuming this still has it's relay with a fuse on the front). Those little fingers that the fuse clips into get oxidized and even tho they grip the fuse tight, current don't flow thru. Try taking the fuse out and cleaning the insides of the fuse fingers if you get the thing to drop in with your hot wire.That way you'd have your kickdown function back.
Thanks for the info so far. I pretty sure the govoner is bad because when I ground the wire running to it the solenoid clicks. This would indicate a good circuit, correct? I have replaced the relay and throttle swith because of some broken terminals. I ran a hotwire or 12 volts to the solenoid just as a check and when it still did not engage, it lead me to believe something else as well as the govoner was bad. The lockout cable is not pushing the lever completely against the stop, maybe a 8th of an inch short of it. When u work the lever on the trans. by hand it is very loose no resistance at all once its moved from conventional gear position, is this normal? I intend to adjust the cable to see if that does anything. Any other ideas would be a help
It does sould like maybe the governor's bad. And you've proven that going around the relay doesn't help. I'd wire it up using your toggle switch to provide a ground to that wire that normally would go to the governor. That way you have the kickdown circuit in operation again AND you have the protection of the fuse in place again.
But remember - actuating this system manually dispenses with the safety of preventing the OD from being engaged when you shift to reverse! You only need to try and back up ONCE with the OD engaged and you've made a mess of the OD unit![xx(]
>>That could be enough to cause you trouble. Ask me how I know
>>If the tranny is in Reverse when you try this, that's exactly what happens, as the OD shift rail has already been pushed back by the internal linkage in the tranny, so that the external lockout lever actually does nothing.
If your overdrive relay really is bad, you might try this:
https://www.studebakerparts.com/stud...ges/relay.html
Take a good look at the wiring diagram in the manual and be sure you have it wired correctly. It is easy to do it wrong!
COOL DEAL! The forum to the rescue once again![:0]
Hey Gord, I adjusted the cable. that was the problem, everything works now even the govoner. I figured it would be something simple, not that simple but anyway thanks..
That cable adjustment can be a real "gotcha". I know it got me! It's so darn basic, it's easy to overlook it, especially if you haven't been warned of just how critical that adjustment is.
Another great job by the SDC Forumers!
So how about this.....
My OD operates fine (knock,knock,knock) while engaged. My problem is I cannot DISengage it. I really don't have a reason to disengage it, but since it is supposed to I'd like it to work.
Bob Palma got me squared away a few years ago on how to engage the OD, but I don't know how to disengage. There has to be more to it than just pulling out the lever. Mine won't budge.
Any help????? Thanks.
Jim's pride....
1963 Daytona Convertible
"but I don't know how to disengage. There has to be more to it than just pulling out the lever. Mine won't budge."
Are you saying you CAN'T pull the OD handle out OR you CAN but it's still in OD???
It DOES disengage below 30MPH or so, right? [}]
