'64 Sedan signal light clicker
  • '64 Sedan signal light clicker
    My signal light stopped working.
    I found the HD can on the floor - I had put that one in as the clicking was weak to thses old engine-damaged ears.
    My hearing is weak, I have been told, as is the flashlight.
    Where the hell is the socket for the clicker-can, anyhow?
    Karl
    When you find the socket, Karl...try one of these...
    http://www.turnalarm.com/
    http://members.aol.com/pclchc/EL98.htm
    Bellingham, WA
      Thanks, Dick.
      In England, I got two 12 vt buzzers (from a house alarm system) and wired one to each wire going to a front signal bulb. (I could have used one buzzer and two diodes.)
      They were a bit too loud so I put an extra layer of double-stick foam between the buzzers and the panel they were taped to. As there was a sound difference between them, I even knew if it was the left or the right that was on.
      I have relatives who might be able to use such things, too!
      Karl
        PLEASE SEE SAME POST ON GENERAL STUDE. DISCUSSION, problem solved!
        Studebakers Northwest
        Ferndale, WA
