stock bolt pattern
  • stock bolt pattern
    What is the stock bolt pattern for a 1961 hawk, is it 5/1/4? how wide can I go will a 17.7 fit?
    Studebakers forever!
    Bolt pattern (as with all Stude cars from '51 up) is 5 on 5 1/2".
    17.7" won't fit unless you tub it.
    Bellingham, WA
      Dick....I think You meant 5 on 4 1/2" circle
      1961 Hawk 4BC,4-SPEED,TT
      Lewisville,NC
      (formerly chevpartsman)
      Ken Byrd
      Lewisville,NC
        I thought you wanted the wheel bolt pattern ( 5 by 4 1/2)
        64 Commander 2 dr.
        64 GT Hawk R2 clone
        64 Daytona HT
        63 Cruiser
        63 R2 4 speed GT Hawk (Black)
        63 Avanti R1
        63 Daytona convert
        63 Lark 2 door
        63 Lark 2 door #2
        62 Daytona HT/ 4 speed
        62 Lark 2 door
        60 Lark HT
        60 Hawk
        59 3E truck
        52 Starliner
        51 Commander
        JDP Maryland
          That's what I meant [:I].
          (hey, I was only off by an inch [B)])
          Bellingham, WA
            Only works in Horseshoes
            Studebaker Fever
            60 Lark
            51 Champion
            Phil
            Arnold, Missouri
            Studebaker Fever
            60 Lark
            56 Power Hawk
            Phil Hendrickson
            Arnold, Missouri
              OK 15 5 1/4 bolt pattern, with the 17.7 is the .7 getting me in trouble? Could it be just 17.5? Our stock wheels are just 15.5 right?
                The bolt pattern is 5X4-1/2. That .2 doesn't make a lot of difference. The widest wheel that will mount without rubbing will be a 6" wide wheel, and even then it will depend on the tire used. Remember, even the Corvettes of the time were running 15X5 wheels and using 7.75X15 rubber. Not a lot of room in the wheelhouses without doing minitubs.
                Tom - Valrico, FL
                1964 Studebaker Daytona
                Tom - Bradenton, FL
                  Depends...
                  Stude used a 5X4&1/2 bolt pattern with a 6.70x15 bias ply tire (on 1961 Hawks').
                  Have your wheel/tire guy check your tire profile compared to the stock setup.
                  It 'might' fit with a 7" wide wheel, depending on the offset, and the sidewall profile.
                  But why you'd want to go there is another matter
                  DEEPNHOCK at Gmail.com
                  Brooklet, Georgia
                  '61 Hawk (project)
                    You can fit an 8" wide wheel on the back of a Hawk with some careful measuring. I am running an 8" wheel with 255/60 tires. The front is more of a problem, but I wanted skinny tires on the front anyway.
                    studelover, are you really trying to fit a 17.7" wide wheel on your car? Or a 17" tall wheel?
                    David
                      Deep hock, I need something to make my hawk stand out. These hub cap just don't cut it. I saw some 16 and 17 inch wheels that have tire packages that I think can make the car a hit. The company Forte has a wheel that would look great on a hawk however it needs to be a 16x6 with a 205 45 16 I think It would fit. I would be giving up the white wall though. The color of my car and the interior must all be on the same level wheels and tires included[8)].
