51 Champion 6 cyl w/OD
  • 51 Champion 6 cyl w/OD
    The overdrive on my Champion 4 door, 6 cylinder with overdrive doesn't want to shift down out of overdrive when I push down on the accelerator all the way. What do I need to check or fiz? Roger
    kickdown switch on throttle linkage and associated wiring...
    good luck
    62 Daytona hardtop
      As a temporary measure until you solve the problem you can get it to shift down by turning the ignition off and back on quickly.
      Don Wilson
      53 Commander Hardtop
      64 Champ 1/2 ton
      WA state
      Don Wilson, Centralia, WA
      40 Champion 4 door*
      50 Champion 2 door*
      53 Commander K Auto*
      53 Commander K overdrive*
      55 President Speedster
      62 GT 4Speed*
      63 Avanti R1*
      64 Champ 1/2 ton
      * Formerly owned
        My 51 Champion comes out of OD when I push the pedal all the way down only once in a while, but I can get it to come out every time if I let of the gas for a moment then mash it to the floor.
          Thanks for your feedback guys. I will try your ideas. Roger
            When my kickdown wasn't working I would just shift to second gear! Champ [8D]
              cwinston,
              Have you tried adjusting the threads on the kickdown switch that's mounted on the accelerator bellcrank, to give a more positive contact when you want to drop out of OD?
              '33 Rockne 10,
              '51 Commander Starlight,
              '56 Sky Hawk
