regulator
  • regulator
    I am hoping that installing a new regulator on a 6volt positive ground system is just a simple straight across job..... is it ?
    It's easy, just mount it, hook the wires back uo correctly and polorize the generator.
    64 R2 4 speed Challenger
    63 R2 4 speed GT Black
    63 R2 4 speed GT White
    63 Avanti
    54 3R Pickup
    JDP Maryland
      How bout a refresher course on the polarizing? Is it field to ground? Do you need to polarize if the battery has been unhooked for a few days?
      I'm asking about a 12 volt neg ground system,though.
      LaSalle,Il
      61Hawk
      60Lark
      Oglesby,Il.
        Make a short jumper wire to short between the battery (B or bat) and generator (G or gen) lugs on the voltage regulator. Only a split-second or a spark is required, so just tap your jumper wire onto the lugs and pull them right back off.
        63 Avanti
        54 3R Pickup
        JDP Maryland
          Polarization is only required if you have a generator, not an alternator. If you have a generator, you should polarize anytime and everytime you disconnect power. Otherwise you stand a 50/50 chance of getting it right.
            A second thought, not related to regu;ators and the like. My 48 went on the freeway for the first time yesterday and I wasn't sure how hard to push the car. Meaning that at about 60 mph the revs sounded pretty high. So I drove about 5 miles right around 60 w/o out attepming 65 . Is 65 advisable or is 60 to 55 mph the proper speed ? By the way the regulator works great ! 48 Land Cruiser six with 3 speed & OD
              Commander six or Champion six? Three-speed or three w/OD?
                Shoot on occasion I used to run the 54 up to 90 with that flathead and OD engaged and it had 4.88 differential gears.
                65 2dr sedan
                64 2dr sedan (Pinkie)
                61 V8 Tcab
                61 Tcab 20R powered
                55 Commander Wagon
                54 Champion Wagon
                46 Gibson Model A
                65 2dr sedan
                61 V8 Tcab
                63 Tcab 20R powered
                55 Commander Wagon
                54 Champion Wagon
                46 Gibson Model A
                50 JD MC
                45 Agricat
                67 Triumph T100
                66 Bultaco Matadore
                  As long as your overdrive is working, higher speeds shouldn't be a problem.
                    He stated that it is a "Land Cruiser", so that would be the larger ("Commander") six. He also stated that it has "od." Sorry, I see that he may have edited answers to your questions into his original question.
                    If you are in overdrive and the rear axle ratio is the original one, I see no problem with 70 to 80 mph, if you feel comfortable with the car's handling and braking systems. What's your hurry <G>?
                    1959 DeLuxe pickup (restomod)
                      My Land Cruiser has the standard "Big 6" for that model. Don't mean to be a nervous nellie, just don't want to do something stupid and expensive. BTW how about a quick break down on gear ratios . I am guessing the higher the ratio the easier the transfer of power through the 3rd memeber ?
                        Watch the oil pressure and keep the oil clean,
                        The 48 Land Cruiser is a highway machine.
