Installation Placement Photos '63 GT
  • Installation Placement Photos '63 GT
    I have 2 parts I have purchased for my '63 GT Hawk.
    I can't seem to find photos for the proper placement of these 2 items
    1. Inner fender splash guards. Missing when I purchased the vehicle, Purchased replacements from SI, but can't find a photo of exactly how the should be positioned
    2. Dual rear antennae. Need to know where abouts on the fender these should be mounted.
    Thanks in advance for your help....
    Chris
    Dual antennas were not a 63 option. This is the best I can do. (Spash guards not intalled.
    64 R2 4 speed Challenger
    63 R2 4 speed GT Hawk
    63 Avanti
    54 3R Pickup
    JDP Maryland
      Thanks, but don't the splash gouards mount from the under side? I can see remanants from that were removed from the PO, but trying to figure out where they line up, etc. I'll have to peek under a car or 2 in a few weeks in South Bend
      I know the dual antennae were not '63 options, but think they look pretty cool nonetheless, just trying to figure where they were generaly mounted on other years.
      Thanks.
      Chris
        Thanks.
        Chris
        You can probably get a copy of the factory template for mounting these antennas for a dollar from the SDC template keeper.
        1959 DeLuxe pickup (restomod)
          No, they mount on the inside of the inner fenders and hang down over the openings between the inner fenders and the frame. They were originally secured by heavy staples; I'm not sure how to duplicate this exactly. What I've done on the radiator baffle, and would probably work with the fender flaps, is to "clean up" the staple holes with a tiny drill bit, contact cement the rubber in place, carefully poke holes through the rubber from the backside, and then cut my own "staples" from stainless wire and manually set them in place. Sounds like a lot of work, but I don't happen to have a stapler handy that will punch through rubber and automotive sheetmetal :/
          If your inner fenders are original, you can probably find the staple holes, although if they've been well repainted finding the exact original location of the rubber may be difficult.
          62 Daytona hardtop
            The inner fender splash aprons (part # 304810), as stated, attach with staples to the inner fender and reduce tire splash into the engine compartment.
            Classic Enterprises has an inner fender kit to reduce the splash into the extremities of the outer fender. These are non factory steel items; just want to be certain what we're installing.
            Accessory instructions and templates are filed by Dave Mottle, 532 East Ella, Corrales, NM 87048 and, if available, are available to SDC members.
              Chris,
              The splash guards mount on the wheel side of the inner fenders with the staple ends bent over on the engine side. I have an email message ready to go with photos of the splash guards on my '63 Hawk. Reply to the email message that I sent to you so I have your email address and can send another message with the photos attached. I do not have a way to post them to this forum.
              Dale
                quote:Originally posted by blackhawk
                Chris,
                Dale
                Posting photos to this list is easy (says he with a laugh ),
                Instructions are under the "Your Studebaker Forum" near the top, all you require is a free account at say Flickr like me and away you go.
                John Clements
                Avantilover, your South Australian Studebaker lover!!!
                John Clements
                Christchurch, New Zealand
                  John Clements
                  Okay. I will try to find time today to sign up for a Flickr account and post the photos. I sent them to Chris this morning. Thanks for telling me how to find out how to do this and where to do it. Dale
                    Maybe something changed for the later cars, but I don't recall ever seeing a car with the splash guards mounted on the wheel side of the inner fender. I know on my '55 and '56 both had them on the engine compartment side.
                    62 Daytona hardtop
                      Okay, here are the photos of the splash guards on my '63 Hawk.
                      Dale
                      0746 - underside of right inner fender (passenger's side) viewed from behind tire. You can see where the heater core is mounted above the splash guard. The heads of the attaching staples are on this side with their ends bent over on the engine side of the inner fender.
                      0749 - underside of left inner fender (driver's side) viewed from behind tire.
                      0750 - engine side of left inner fender. You can see the inside of the splash guard and the bent over ends of the staples (the hydrovac brake unit is removed at the moment).
                      0751 - engine side of right inner fender. The splash guard is on the outside of the engine circulating heater which is visible below the heater core housing (circulating heater has red hose coming up from its top). You also can clearly see the bent over ends of the staples on the inner fender just above the heater hose behind the alternator.
                        Does anybody know what material you might use to make your own splash guards?
                          They are rubber reinforced with nylon cords, heavier than tire tubes but not as heavy as a tire sidewall. SI has them for $15 each; hardly worth the time to find a material and cut them.
                            Just order them from Studebaker International. They are die cut to the original pattern.
                            Dan White
                            64 R1 GT
                            64 R2 GT
                            Dan White
                            64 R1 GT
                            64 R2 GT
                            58 C Cab
                            57 Broadmoor (Marvin)
                              thanks everyone, I think I can get them on correctly now. I could see some partial photos in the shop manual, but these photos really clear eveything up. I purchased mine from SI.
