Oil pan remove 48 Champion?
  • Oil pan remove 48 Champion?
    Shop Manual says remove engine to replace rod bearings? Anybody know any short-cuts? Thanks! Champ
    Yes, pull the engine. It's quicker than what you'd have to do trying to drop the pan in the car. You can pull a flathead six in about 2 hours tops.
    64 R2 4 speed Challenger
    63 R2 4 speed GT Hawk
    63 Avanti
    54 3R Pickup
    JDP Maryland
      I won't say it COULDN'T be done IN the car. But I sure wouldn't want to try![}]
        Thanks JDP AND Mr. Biggs, I'm not 100% sure that it is rod bearing knock! Champ
          Maybe I am missing something. couldn't you undo the engine mounts, jack the engine up and shove blocks of wood under them, then drop the pan and roll new shells in in the car?
          BTDT... but not in a Studebaker...
          62 Daytona hardtop
            N8 not enough room to do that. BTW, make sure it's a rod knock, piston slap is not unusual on a Champion.
            63 Avanti
            54 3R Pickup
            JDP Maryland
              Would piston slap be caused by a worn wrist-pin? I seem to remember that they would last a long time if driven normaly? The engine was rebuit about 4,000 miles ago by previous owner. Thanks Champ
                Describe the nature of the knock. Only hot, cold, both? Under load - no load, acceleration - deceleration. Dull thud, sharp clack?[:I]
                Oh - and what's the oil pressure like?
                  I think the 48 is like my 47 Champ, the front suspension is the transverse spring which sort of makes the pan real hard to remove in the car. It is easier to pull the engine than it is to pull that spring
                  Milt
                  Milt
                  1961 Hawk 4-speed
                  1967 Avanti
                  1961 Lark 2 door
                  1988 Avanti Convertible
                  Member of SDC since 1973
                    Traverse spring AND a front sump pan, pull the engine.
                    63 Avanti
                    54 3R Pickup
                    JDP Maryland
                      No noise till it warms up. Noise starts at 12 to 15 mph. in 1st gear, 20 to 25 mph in 2nd gear, 42 to 45 mph 3rd gear and a little over 55mph in o.d. Under load yes steady speed yes acceleration yes deceleration no noise. More like a rattle than a dull thud or sharp clack. oil pressure is over 40 cold, a little over 30 at highway speed, and over 20 at idle. Thanks again Champ
                        Good news! The noise in my engine was the water pump! Also found a bad front motor mount. I think the bad mount was causing the noise to resonate and make the noise sound different than what it was. Champ[8D]
