56 door hinges
  • 56 door hinges
    Just removed my doors off my 56 2dr wagon. Two of the hidges swing freely the other two are as hard as a rock. I have to hit the with a hammer to move them. Which two are ok and which two need repair? One on each side are like this. Can these be repaired??? Thanks
    Well, have you soaked the two tight ones with some sort of penetrating oil (not WD-40)? Something like Kroil or PB Blaster?
    If the two that swing freely don't wobble or flop around when they move, they should be OK. Oil them up good with 3-in-1 or some like product - do this to the tight ones too, after you've got them loosened with the penetrant. Then give us a report.
      I just sprayed them with BP Balster. I'll give them some time to soak. If this doesn't work I'll remove them. Thanks. I'll keep you posted.
        Well, after 3 days of pb blaster and alot of working the hidges back and forth they are begining to loosen up. It looks like they will survive this time. Thanks.
          Good to hear!
            After you have them good and loose, I'd spray in some lithium. The Blaster will help the lithium penetrate the hinge.
            When we change the oil and lubricate on a regular schedule, we often neglect the non-drivetrain moving parts. Lubricating door, hood and trunk hinges and latches should be an annual event. Use Door-Ease on striker plates and hood and trunk latches; graphite in window channels and lithium on window regulators and window lift tracks.
            "An ounce of prevention is worth a pound of cure."
