It CAN be done!
  • It CAN be done!
    I finally decided to stuff the Avanti R2 engine I've been hoarding under the hood of the '53, but I didn't want to lose the AC or Power Steering (or cut any holes in the hood!). 'Had to notch the fender well and lose the mechanical fuel pump, but managed to get it done in fairly tidy fashion I think.
    Steve Hudson
    The Dalles, Oregon
    1937 Dictator Streetrod
    1949 "GMOBaker" 1-T Dually
    1953 Commander Convertible
    1954 Champion Coupe
    Steve Hudson
    The Dalles, Oregon
    1949 \"GMOBaker\" 1-T Dually (workhorse)
    1953 Commander Convertible (show & go)
    1953 "Studacudallac" (project)
    Wow! What a setup...
    That's for that convertible right? I guess it IS possible to perfect an already perfect car. [^][8D]
    __________________________________
    Matthew Burnette
    Hazlehurst, Georgia
    '59 Scotsman PU
    '63 Daytona HT
    http://georgiastudebaker.com/
      Real nice looking work Steve!
        I'm partial to your paint color choice. And I bet yours will be faster than mine. Here's why
        [img=left]http://rocketdillo.com/studebaker/misc/images/Avacar-hcsdc.gif[/img=left]DilloCrafter
        1955 1/2 Ton Pickup
        The Red-Headed Amazon
        Deep in the heart of Texas
        Paul Simpson
        "DilloCrafter"
        1955 1/2 Ton Pickup
          SWEEEEET! And I thought that '53 just couldn't get any better!
          <div align="left">Tim Stevens Big Sky Country, Montana '59 4E7-122 '59 Silver Hawk '57 Parkview Wagon '41 Double Dater Coupe</div id="left">
          I own time machines.....
            Great job Steve. That shoe-horn came in handy......
            Brian K. Curtis
              Paul, I'm tellin' ya - that chromed harmonic balancer's gonna add 20MPH to your top end![:0]
              20"MPH" = mirror plated hysteria
              Steve - that's impressive! One busy front end![]
              Miscreant adrift in
              the BerStuda Triangle
                Nice job Steve! Did you have to have all of the pulleys custom made for the serpentine belt grooving? I would doubt that any "V" belt could handle all that!
                Studebakers Northwest
                Ferndale, WA
                  I don't know if you will be running many rpm's or not but if so, I'm thinking the supercharger belts will slip before many rpm's are reached due to the small amount of "wrap" on the pulley. It appears you could help this by running the belt on top of the idler (tension) pulley and use a turnbuckle to tighten it. I did this when I put the second supercharger on the CH and it really helped.
                  Ted
                  Steve Hudson
                  The Dalles, Oregon
                  1954 Champion Coupe
                    Thanks for the tip, Ted. I don't expect to be running a lot of R's, but you never know. I already replaced the spring with a a turnbuckle, so it shouldn't be too difficult. What kind of tensioner roller did you use?
                    Steve Hudson
                    The Dalles, Oregon
                    1954 Champion Coupe
                    Steve Hudson
                    The Dalles, Oregon
                      I went to Tractor Supply I think it was or maybe a large hardware store and bought a riding mower pulley with the same diameter hole to bolt it on the arm. I was using the Lark/Hawk type single wide belt so I got one with a "flat" that was wide enough for the outside of the belt to run in it. I would guess if you got a pulley wide enough for your two belts it would work without the individual grooves. The lawn mowers use a single belt similar to the belts on the Avanti pulleys so if it were flat and wide enough I don't think there would be a problem.
                      Ted
                      Steve Hudson
                      The Dalles, Oregon
                      1954 Champion Coupe
                        Dang it, Ted, that is not high tech enough!
                        The PC answer is billet aluminum with your own tight tolerance specification.
                        Lark Parker aka Trim Trader
                        Lark Parker --Just an innocent possum strolling down life's highway.
                          Is that two v-belts or a groved sepentine? If its a groved
                          serpentine you could try an LT1 belt tensioner :
                          Tom
                            Serpentine? I wish. Has anyone even done that yet? Sounds like a project for Jeff or Dick. What I did stretched the limits of my feeble abilities. And yes, the supercharger will ultimately get the full strip and polish treatment.
                            Steve Hudson
                            The Dalles, Oregon
                            1954 Champion Coupe
                            Steve Hudson
                            The Dalles, Oregon
                              Holy Smoke, Steve! Have you ordered new front springs yet![8D]
                              Miscreant adrift in
