Brake fluid
  • Brake fluid
    After replacing or rebuilding the entire brake system on my 63 hawk, I now read an article in hemmings touting the value of silicon brake fluid, Anyone have any experience with the stuff or Am I just out of the loop? Everything I read says Dot 3 brake fluid . Any thoughts?
    Thanks
    quote:Originally posted by jfh
    Any thoughts?
    From this group [:0]. (You're kidding...right[?])
    Bellingham, WA
      I've used the silicon fluid in several of my Studes with no problems
      (eg) premature brake light switch failure.It does not absorb moisture
      so cylinder rust from sitting is less likely.A bit on the expensive side but worth the expense if you are going to keep the car.
        here's some light reading for you
        http://groups.google.com/group/alt.a...t=0&scoring=d&
        62 Daytona hardtop
          www.studegarage.com
          Gary Ash
          Dartmouth, Mass.
          ’41 Commander Land Cruiser
          '48 M5
          '65 Wagonaire Commander
          '63 Wagonaire Standard
            Dont forget about Synthetic .....
            http://www.valvoline.com/pages/produ...asp?product=51Avanti, 102,000, custom made brake brackets to mount 1998 Mustang GT 4 wheel disc brakes (soon to get 13" Cobra front brakes, 2003 Mustang Cobra 17" wheels, GM altenator, will be getting : 97 Camaro Z28 tan leather seats, 97 Camaro Z28 T-56 6-speed trans, Ported 'R3' style Avanti heads with stainless full flow valves, 'R3' 276 duration cam w/chrysler solid lifters, shortened push rods, aluminum cam gear, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires, waiting in the garage.
              I endorse everything Gary Ash said. I have used silicone brake fluid in several of my collector cars for more than 20 years with absolutely no problems. The metal parts don't rust, and the fluid doesn't get muddy. If you have rebuilt the entire system, I would recommend filling it with silicone fluid, especially if the car is driven infrequently. Otherwise, stick with what you've been using. Rubber parts like brake hoses and wheel cylinder cups apparently don't take kindly to being exposed to different fluids.
              There have been a number or reports that the brake light switches used on Studes and other cars of that era tend to fail more frequently with silicone fluid. I have not had that experience.
              Skip Lackie
              Skip Lackie
                The stop light switches that are compatable with DOT-5, can be had at your local Harley Davidson M/C parts counter. They are a little pricey, but name something from H/D that isn't.
                Dan Miller
                  Since redoing my brakes, that had jelled w/ DOT3 a number of years ago I have used DOT5 in my R1 Hawk with no problems except the light switch once. I got a new one from Ron Francis that sells a DOT5 compatible one. Good pedal feel and no jelling and screwed up calipers/pistons.
                  Dan White
                  64 R1 GT
                  64 R2 GT
                  Dan White
                  64 R1 GT
                  64 R2 GT
                  58 C Cab
                  57 Broadmoor (Marvin)
                    I ditto what Skip Lackie says about Silicone Fluid. I put it in my '50 Starlight Coupe in '94 when I installed new lines, hoses, master & wheel cylinders. 7,000 miles later, no problems and no brake light switch problem either. I bought a '64 GT R1 Hawk last May and am not going to convert to Silicone unless I plan to replace all fluid components (not in my immediate plans). Just my 2 cents worth.
                    Happy Cruising All [8D]
                    StudeBakerHarv
                    StudeBakerHarv
                    * 1950 Champion Starlight Coupe (Cathcart Stg 4 Engine)
                    * 1971 Avanti II (RQB-1659).
                      Silicone compatible, low pressure contact, brake light switches are also available from Ron Francis Wiring at:
                      http://www.ronfranciswiring.com/
                      In particular: http://tinyurl.com/j7bcr
                      Dan Miller
                        Synthetic is compatible with all fluids .......
                        If you have a Lark with swinging pedal, or Avanti, its SUPER easy to
                        just install an electic stop light switch, works considerably better
                        then the hydraulic pressure one.
                        Oh .. did I mention Synthetic?
                        Tom
                          Be careful here when talking about synthetic, and silicone brake fluid.
                          Yes, synthetic DOT-3 and DOT-4 is compatible with non-synthetic DOT-3 and DOT4, but it is NOT compatible with DOT-5 (silicone) brake fluid.
                          Some interesting reading is here:
                          http://groups.google.com/groups?q=Is...roups&ct=title
                          http://www.findarticles.com/p/articl...23/ai_n6221217
                          http://www.adlersantiqueautos.com/articles/brake2.html
                          http://www.shotimes.com/SHO3brakefluid.html
                          Just food for thought.
                          Tom
                            Thanks for catching that .. I was answering two separate questions at
                            work (sneaking it in) and I failed to break them up better. Synthetic
                            is not compatible with silicone. Synthetic is a better alternative
                            then going with Silicone, since it has the benefits of Silicone, but
                            not the drawbacks (stop light swtiches). If you choose to go with a
                            Silicone blend, then if you have a swinging pedal Studie, the change
                            to an electric switch is quite simple.
                            Tom
                              I have used all three DOT 3, 4, and 5. In my Studes since I drive them regularily I use DOT 3 or 4 but for my nephew in his 68 Cougar I used DOT 5 simply because I knew that it was only going to be driven occasionally and hard on those occasions.
                              In any case when I rebuild brakes I apply silglide liberally. I am still driving with brakes that I did some twenty years ago due to the fact that I use liberal amounts of Silglide and it keeps the rubber parts pliable and the wheel cyllinders from rusting internally.
                              So for a daily driver I would not use DOT 5 but for a trailer queen you bet.
                              65 2dr sedan
                              64 2dr sedan (Pinkie)
                              61 V8 Tcab
                              61 Tcab 20R powered
                              54 Champion Wagon
                              65 2dr sedan
                              61 V8 Tcab
                              63 Tcab 20R powered
                              55 Commander Wagon
                              54 Champion Wagon
                              46 Gibson Model A
                              50 JD MC
                              45 Agricat
                              67 Triumph T100
                              66 Bultaco Matadore
