Grommet Help Request
  • Grommet Help Request
    A little Stude type help please....
    Need to find a source (an easy source if you please) for these two (non-Stude?) grommets.
    They are (or should be) a fairly hard rubber used for vibration isolation.
    They each get pressed through a metal bracket and a 3/8" bolt gets passed through the inside.
    I have no clue where they originally came from.
    Maybe somebody recognizes these and can suggest a good source.
    Thanks ahead of time...
    DEEPNHOCK at Gmail.com
    Brooklet, Georgia
    '61 Hawk (project)
    Have you tried metro moulded parts? They have a web page and their phone # is 763-757-0310. They make lots of rubber parts.
    28 dictator
    40 commander
    28 dictator
    40 commander
      Jeff, you can spec grommets by:
      1. The diameter of the hole in the metal
      2. The thickness of the metal
      3. The diameter of the hole in the middle [you said 3/8]
      4. Rubber hardness [50 durometer BUNA-N is softer, 60 durometer SBR is harder]
      Try here: http://www.marcorubber.com/grommetsearch/search.asp
      Dartmouth, Mass.
      '48 M5
      '65 Wagonaire Commander
      '63 Wagonaire Standard
      Gary Ash
      Dartmouth, Mass.
      ’41 Commander Land Cruiser
      '48 M5
        I take measurements and order from McMaster-Carr.
        http://www.mcmaster.com/
          Might check your local Honda (motorcycle) dealer's parts dept.
          Steve Hudson
          The Dalles, Oregon
          1937 Dictator Streetrod
          1949 "GMOBaker" 1-T Dually
          1953 Commander Convertible
          1954 Champion Coupe
          Steve Hudson
          The Dalles, Oregon
          1949 \"GMOBaker\" 1-T Dually (workhorse)
          1953 Commander Convertible (show & go)
          1953 "Studacudallac" (project)
