12V to 6V signal conversion
  • 12V to 6V signal conversion
    Just found out my directional signal switch has disassembled itself Rather than try to put it back together, thought I would buy one of these 12V units if it will work on my 6V system. If I just change the 12V flasher solonoid to a 6V flasher, is there any reason it would not work?
    Dave D.
    '51 4-dr Champion
    Smithers, B.C.
    Canada
    It should work so long as the pin configuration is the same on the two flashers.
      Confused.....what does the directional switch have to do with the flasher? The turn signal switch is mounted in the steering column and the flasher is plugged into the board with the couple fuses and circuit breaker. The TS switch does not care at wich voltage it runs at.
      65 2dr sedan
      64 2dr sedan (Pinkie)
      61 V8 Tcab
      61 Tcab 20R powered
      54 Champion Wagon
      65 2dr sedan
      61 V8 Tcab
      63 Tcab 20R powered
      55 Commander Wagon
      54 Champion Wagon
      46 Gibson Model A
      50 JD MC
      45 Agricat
      67 Triumph T100
      66 Bultaco Matadore
