4 lug to 5 lug conversion
  • 4 lug to 5 lug conversion
    Does anyone know what's involved with converting a 4 lug '50 Champion to 5 lug front hubs and preferably disc brakes?
    4 to 5 lug
    rather simple
    find yourself a newer stude of a sort
    i think a 57 and up
    rob the spindles baking plates and drums and viola 4 lug turned to 5 lug
    now you said preferably disc so step it up a notch
    find a stude with disc brakes
    rob the spindle and all the hardware from there out
    what the scenero is here is that from 51 and up stude used the same
    spindles
    so any thing newer has a bolt pattern of 5 lug on a 4.50" bolt pattern
    now i found with some year models you may have to make a shim to get a good fit on the kingpin to spindle (had to do in my case)
    but the whole conversion was fairly simple
      56-up are all the same for brakes. Only thing is I think the kingpin and lower knuckle changed at some point in time so you'd want to make sure you didn't mix and match parts otherwise you might end up with some weird caster. Actually '55 brakes would work but the hub, inner bearing, and grease seal are different on the front from all the later cars. Still 11" front and 10" rear drums on all cars.
      62 Daytona hardtop
        Nate are you sure.....I am sure that I have pulled some Champions a part and they had ten inch drums in the front and nine inch drums in the rear.
        65 2dr sedan
        64 2dr sedan (Pinkie)
        61 V8 Tcab
        61 Tcab 20R powered
        54 Champion Wagon
        65 2dr sedan
        61 V8 Tcab
        63 Tcab 20R powered
        55 Commander Wagon
        54 Champion Wagon
        46 Gibson Model A
        50 JD MC
        45 Agricat
        67 Triumph T100
        66 Bultaco Matadore
          If you just wanted to change to 5 lugs couldn't you just remove old lug studs and drill to 4 and1/2" bolt pattern? Champ[8D]
            Sorry, I was just ASSuming that the OP would be using a V-8 parts car for the conversion, which would be the sensible thing to do if he went with drums. I have to admit that I think brakes are fairly important, so even if I had a six I probably would have put the V-8 brakes on it by now. With the Studebaker discs, obviously you would want the matching 11" rears. I think the self-energizing 10" rears are supposed to work OK with the Turner conversion though.
            Not sure if the rears will bolt up to the early rear axle, were they using the Dana 27 or 44 by '50?
            62 Daytona hardtop
              drilling is NOT the way to go let me save you the time trouble and headaches
              i drilled my old rear drums and because they are a 2 piece hub and brake drum pressing in new studs caused the hub (cause such thin metal) to warp and even cracked one of the drums they were basically unsalvagable (eggshaped)
              and keep in mind this was all done in a professional machine shop (im a machinest by trade)
              so i highly do not recommend a novice with a drill press and a means of coming up with the proper 5 on 4.5" bolt pattern to tackle this
              im not doubting anyones skills its just i been a machinest for 4 yrs and had help from a 20 yr + vetern machinest
                Nate
                The six cyllinders brakes should work fine if they a kept up and propperly adjusted. After all we are talking about a Champ just with the four bolt pattern. I had the 54 out last week and some cell phone talking idiot decided to lock em up in front of me so they could make an illeagale left hand turn accross two lanes of traffic. I had enough time to say Oh sh before I dynimited the brakes in the 54 and she locked up the rears but went straight and I had good twenty feet to spare.
                65 2dr sedan
                61 V8 Tcab
                61 Tcab 20R powered
                54 Champion Wagon
                65 2dr sedan
                61 V8 Tcab
                63 Tcab 20R powered
                55 Commander Wagon
                54 Champion Wagon
                46 Gibson Model A
                50 JD MC
                45 Agricat
                67 Triumph T100
                66 Bultaco Matadore
                  My perspective may be a little warped; I live near DC and normal freeway speeds are in the 75 MPH range and people drive stupid here. IMHO you can't have too much brake or tire in this area. I don't feel comfortable without at least the V-8 drums and I would prefer discs (probably going to go down that road someday.) Once I get my car all "shook down" I will probably be looking into a front disc conversion and a dual circuit MC.
                  In any case the V-8 brakes are demonstrably better than the six brakes even if you feel the six brakes are "adequate" if you had the choice I would recommend the V-8 ones. If nothing else without a pressure booster you will have a lighter pedal with the V-8 stuff.
                  62 Daytona hardtop
                    Thanks for all the input. I know 51 stuff is more interchangeable with later but 50 is somewhat by itself I'm told. I have had 80 plus cars and have built 3 from the ground up. I'm a plastic injection mold type machinist and have CNC's and several drill presses so I can fab if necessary, but I am new to Studes as far as what will fit what.
                    I have access to a set of 55 brakes and a complete rear. I just want to find out what will work best on a budget. I was planning to just drive this car mostly stock with a nice set of wheels. I have a 55 State Hdtp that is getting the full on rotisserie job as well as a 53 nose but I would like something to drive without starting a new major project. Someone said that the 55 brakes won't go without a little work?
                    Thanks a bunch for all your help. Should I bag the 55 stuff and look for later to save myself some time & grief?
