Engine ID help
This topic is closed.
  • stude_s
    Mr Biggs.
    Thanks for time you put in!
  • Roscomacaw
    I did a bit of figuring and this would be the 1,803rd standard duty 259 assembled during the 8E series run. I'm sure it would have been in a '63 edition 8E truck. Champ or larger C-cab? Who knows[B)]
    Miscreant at large.
    1957 Transtar 1/2ton
    1960 Larkvertible V8
    1958 Provincial wagon
    1953 Commander coupe
    1957 President 2-dr
    1955 President State
    1951 Champion Biz cpe
    1963 Daytona project FS
  • stude_s
    Thanks for all the full flow info...
    Any idea on the year?
    Thx
  • Transtar60
    Mr. Biggs,
    There was one of those HD truck filters on ebay about two weeks ago, a NOS kit. I let it pass cause, I prefer the spin on filters. The cannisters have too many places to leak<G>.
  • Roscomacaw
    "Can any full flo filter base attach, or is anything additional/special needed to complete the change over to the full flow system?" [?]
    Yup, any base. And there were TWO of them available. One for cars and one for HD truck applications. The HD unit accepts a cannister and element type filter, I believe. I've never actually seen one mounted on an engine. But I have one I bought at a swap meet, just for grins.
    So, you'd need a base, a gasket and a filter, of course. OH, and plugs to plug up where you'll remove the partial flow filter lines. 1/8th inch pipe thread plugs.
    Miscreant at large.
    1957 President 2-dr
  • Alan
    1555771 Oil filter base and 1555103 oil filter base to block gasket.
    1555771 $40.00, 1555104 $2.00, SI catalog of parts.
    Still uses an odd ball thread same as 60-72 Buick, Olds and Poncho.
  • stude_s
    Mr Biggs,
    You are correct! I didnn't get all the gunk off, the full serial number is 3E20704![:I]
    Thx
  • Roscomacaw
    3E would denote a standard duty 259 from a truck. I've come across a couple of these with that plate you speak of. You can replace it with the full-flo filter base (that's what I'd do!).
    Thing is, that number you gave (specifically the four digits AFTER the 3E) is too low to be a full-flow engine. Are you sure you didn't forget a digit??? Should be at least 5 digits after the "3E"
    Miscreant at large.
    1957 President 2-dr
  • stude_s
    Guest started a topic Engine ID help
    Engine ID help
    OK, I rouned up a stude V8 from a local "stude yard" for my '60 lark. I'm having some trouble iding it and am looking for some help!
    I know its from a early 60's truck, probally a 62-64 259 due to the valve covers are yellow and the oil caps are orange. The crankcase vent system looks the came as a '63 car per the car chassis manual. It has a plate on the right rear; would this be for the full flow oil filter adapter? It has the original canister filter above the valley pan.
    Serial number is: 3E2070.
    Thnanks in advance for the help.
