63 Hawk Tach Trouble Shooting/Repair
  • 63 Hawk Tach Trouble Shooting/Repair
    I Am restoring a 63 GT Hawk and want to get the Tach working. I did a search of the forum
    and found some limited information. The most information was from NJN on 56-61 Hawks.
    I don't know if the 63 Tach used the same system. My tach is completely disconnected--
    no wires from same. The manual is no help.
    Anyone that has wiring and operation information, on how to proceed to repair, PLEASE
    help me get this instrument working again.
    Dick Curtis
    50 Champion Starlight
    63 Hawk GT
    It's different from the earlier Hawks, I know that.[:I]
      Start here: http://www.ncsdc.com/TechnicalPages/GTTachs.htm
      If the tach does not work when the wiring is connected it is probably in need of a new sending unit. These are available from the Stude vendors. Be sure that there is a seperate ground wire running from the housing of the tach dial to a good ground behind the dash.
      Tim K.
      '64 R2 GT Hawk
      Tim K.
      \'64 R2 GT Hawk
        Dick, I also have a '63. The ones with jet thrust engines have a different sender. It is round like a hockey puck (but silver or chrome looking, not black), while the sender for the standard V8 is rectangular. I have a diagram but no scanner or web site to post a digital image, so can't get it to you right now. I've seen this information before, in Turning Wheels probably, so think it won't be long before someone posts it for you. I can scan the diagram I have when I go to work on Monday. Dale
          Thank you all. The engine in my Hawk appears to be the two barrel standard 289 V8.
          One wire comes off the coil 12 volts and leads through the firewall and has been cut.
          A nearby wire appears burned on the insulation. The instruments bulb has been removed.
          Not happy signs.
          Dale, I would much appreciate the diagram. If it can't be emailed, let me know and I'll give you my snail mail address.
          Off the subject, but I'm going to NAPA store to pick up oil, filter,plugs etc . Only have had the car a week so learning many things. I use nondetergent oil in my 50 Starlight since partial flow oil filter. Is it wise to use modern oil in the 289 ?
          ...Dick
          The 1950 Champion Starlight
          Santa Barbara
          CA
