6 volt batteries
  • 6 volt batteries
    Aside from Optima or Ultima or whatever, are there any reliable six volt sealed or low maintenance batteries available? I'm tired of cleaning and repainting steel parts in my engine room. The batteries I get seem to bubble acid. (even when the car sits for three months.}
    Three months to South Bend!
    Tom Bredehoft
    '53 Commander Coupe
    '60 Lark VI
    '05 Legacy Ltd Wagon
    I sometimes acquire my 6 Volt batteries at CarQuest and have had no problem with those I've used. I don't check the water but every few months and they last 2-3 years.
    '55 Commander
    '55 President
    \'55 Commander
    \'55 President
      Here's what I would do...
      http://www.batteriesareus.com/index....products_id=83
      Bellingham, WA
        Could you put a rubber container under the battery. It loooks like a shoe box lid, I would think this would solve the problem.
          yup, I would use a plastic tray and a "battery mat" to soak up the acid, also check the output voltage of your generator, make sure it is not overcharging, should only be about 7.2 volts MAX or you will get the boil 'n' bubble effect.
          good luck
            The bubbles burst, spraying the whole side of the compartment. I have the 'battery mat', the battery is three years old, I've never had to add any water.
            Dick, I LOVE your suggestion. It even appears to be a 'tar top.'
            Thanks Guys.
            Tom Bredehoft
            '53 Commander Coupe
            '60 Lark VI
              That IS a really neat looking fake "OLD" battery, I like it. But there is only one problem, I read the detail and it says it's a Group 2, Studes use a Group 1. That one is a Ford Batt. with is longer and requires the box to be cut and extended and might look a bit "wrong".
              Studebakers Northwest
              Ferndale, WA
                Please explain the terms for Group 1 and 2 - by the way, I used an Optima and thought it was great. Never had a starting problem once I bought it.
                Chris Pile
                The Studebaker Special
                Midway Chapter SDC
                  Groups 1 and 2 just refer to the physical size of the 6 volt battery. A typical 6 volt equipped Stude has a battery holder that only a Group 1 will fit into. But a tractor supply store or good FLAPS should be able to get a Group 1, 6 volt battery for you with a high cranking amp. rating.
                  Also, I totally agree with the other poster about getting your voltage regulator checked. A malfunction in it can be the cause of the bubbling and acid spray. In fact, there shouldn't be acid spray of the amount you are observing, unless there IS a problem with the charging system.
                    Three years ago I replaced a battery that wouldn't hold a charge with the one I have now. At that time the entire system was checked for good charging and regulating. That battery dribbled out of the top. It was replaced in six months with no charge. The new one spits, not as bad ad drooling, but not good. The system was re checked at this time. I like the idea of the Optima, will get one. It will fit (on a diagonal) in my No. 1 battery box, the other dummy tar top won't fit.
                    I'd think over charging was a problem, too, but it continues with the battery out of the car. When I took it out last week I wiped it dry. Its wet now. And yes, it is out of the weather.
                    I was hoping there was a series one sealed 6 volt battery. It doesn't seem so.
                    Tom Bredehoft
                    '53 Commander Coupe
                    '60 Lark VI
                      I've been getting group 1 from Interstate for years and had no problem.
                      '33 Rockne 10,
                      '51 Commander Starlight,
                      '56 Sky Hawk
                        The Interstates are good.
                        You also might try Pep Boys and Autozone.
                        Rog
                        '59 Lark VI Regal Hardtop
                        Smithtown,NY
                          When it comes to batteries getting wet on top, that's pretty much a given unless you look at something like a motorcycle battery which has sealed caps and a vent tube that exits elsewhere. Anytime a battery is charged, hydrogen and oxygen gas is formed as water breaks down and this gas has a tendency to carry sulfuric acid along with it. Slow trickle charges carry the least while fast, high amperage charges carry the most. When charging, the gas must have some place to go. Old batteries had holes in the caps and many "no maintenance" batteries may have flat tops but aren't even close to being totally sealed. I've pried the tops off of many of them to refill with water or check the specific gravity. The only reason they're considered no maintenance is because they contain enough extra electrolyte that they normally don't run dry during their expected life. The so called sealed batteries are usually nothing more than a ordinary battery with extra air space and recessed filler holes that happen to have a sticker pasted over the top. Peel that sticker off and they're just like any other battery except they usually don't vent much gas. The batteries that vent the greatest amount of gas are those small sized batteries with high cranking amps. They get their high capacity by stuffing more plate area into the cell which leaves less room for electrolyte. Motorcycle batteries are probably the worst in that regard and because of that, they go through a lot of water for their size. At the opposite end of the spectrum are large ag, over the road or industrial batteries, the ones several feet long and weighing 80 pounds or so. They have a lot more electrolyte for the amount of plate area than auto batteries and usually don't loose as much water unless they go through a lot of deep discharge-charge cycles or are being overcharged. When the average auto battery is covered with the barely perceptable acid vapor layer, they loose about .1 volt and something like 1% of their total charge per month. If your battery vents a lot of gas, make sure you're not overcharging it and you don't have the cells fill too high. Consider your driving habits also. If you have a generator and do a lot of in town, low speed high electrical load driving before getting on the highway, the generator is going to have to do a lot of charging to replace the lost charge. If you fire it up in the morning and immediately get onto the open road, the battery won't need much recharging and is going to vent a lot less gas. To keep things clean about all you can do is to regularly remove the battery, wash the outside with a mixture of baking soda and water to neutralize the acid and rinse it off with a hose. Just try to keep the soda water from getting into the cells. The only other thing is use a totally sealed battery. Take a look to make sure they really are totally sealed though. Just because they have a plastic sticker pasted over the top doesn't always mean they are, look at each end near the center top of the battery and you might find a small rectangular vent hole. If so, they'll vent gas as well. They make motorcycle batteries with gel electrolyte but they're pricey and I don't know if they make larger one in that manner.
                            I have bought my six-volt batteries from a local battery warehouse- they are usually fresher than ones sitting around in a parts store. I have realized much longer life and much less contamination by keeping a battery maintenance charger on the battery when the car sits. This IS NOT a trickle charger, but one that keeps the battery topped off (charges then shuts off completely and just monitors the battery charge). A few days ago I went down to the cold barn and started my '53 Commander to move it. It hadn't been run for a couple months, but it cranked easily. This was with a five year old battery (and it had been allowed to go completely dead one time when the charger got accidentally unplugged- the maintanance charger brought it back in a few days of slow charging).
                            Museum R-4 engine
                              I need to correct something I put in my earlier post, a battery will loose about 1% of it's charge per DAY, not month. Let's see, per month...gee, at that rate a battery could go dead in something like 8 years! Ha! Sorry for not paying more attention, I should have proofread it better before I sent it. That's why using the maintenance charger like 53k uses is a wise idea for vehicles that set around a lot. That's also why motorcycles with digital clocks and fuel injection need a new battery every spring if they aren't ridden, kept on a charger or the battery cable disconnected. They set all winter while the clock and computer memory keep using juice from a rather small battery. By spring the discharged plates have all sulfated and you have a dead battery that won't take a charge.
