Lifter noise, No! Was Distributor slop.
  • Lifter noise, No! Was Distributor slop.
    I dusted off the Transtar today to haul off some brush. I was returning home when my phantom tap, tap, tap noise started up again[}] I have adjusted these things every way to Sunday, still one made noise, intermittently, and only at certain RPM's. I had pulled the valve springs to replace the seals, and soaked the stems in brake cleaner, and then PB Blaster, no, not a sticky valve
    So, today I got the stethoscope out (yea, should have done that before) and found the distributor was the source. The rotor had been hitting one side of the terminals in the cap, and metal shavings were scattered inside. Things are not always what they first seem to be, learn something every day. I swapped the Petronics unit over to another older Delco I pulled from the wagon (swapped in a "window" unit) and presto, no more noise Much better, runs better too. Think I will drive it to work next week[8D]My driving this truck drives one of my boss's nuts. Sometimes I get there early to park next to his Lex#s, when are you going to get a new car?, we have an image to uphold!, and so on he goes. I love it.
    Ross.
    Riverside, Ca.
    1957 Provincial X2
    1958 Transtar
    1961 Cruiser
    Be sure your engine mounts are in good shape. Something may be causing your distributor cap to cock over.
      when you say you switched in a "window unit" do you mean there's a studebaker distributor that takes the gm externally adjustable points?
        Yes, the GN window unit was used on 61 Larks.
        64 R2 4 speed Challenger
        63 R2 4 speed GT Hawk
        63 Daytona Convert.
        JDP Maryland
          I had replaced the mounts when I first got the truck, that corrected the 1/2 shift hang up.
          I was able to identify the slop by clamping the dist in a vice (with wood blocks) and grabbing the top and bottom of the shaft and moving it side to side. I had to rotate the body and check it in several positions before I found the bad spot in the bushing. Tagged it, bagged it, and stored it for later.
          The Delco "window" unit has pro's and con's. Pro, some che#y parts fit, as do aftermarket parts. Con, there is a little bumper /bushing under the mechanical advance that limits the travel, which goes missing and can cause some head scratching (been there) I never did find a source for this busing, although I did not look too hard.
          And likewise some vacuum advance units had a similar busing, but this is an easy fix using some 1/4" poly tubing. Just my non-expert opinion and observation.
          And of course, window or not, subject to wear.
          I am a stickler on maintenance, and wonder how lack of lubrication plays into wear patterns on different units.
          Ross.
          Riverside, Ca.
          1957 Provincial X2
          1958 Transtar
          1961 Cruiser
          Ross.
          Riverside, Ca.
          1957 Provincial X2
          1958 Transtar
            60 Larks also had the Delco-Remey window type distributer
            Studebaker Fever
            60 Lark
            51 Champion
            Phil
            Studebaker Fever
            60 Lark
            56 Power Hawk
            Phil Hendrickson
            Arnold, Missouri
