Information for a automatic Transmission 1951 Stud
  • Information for a automatic Transmission 1951 Stud
    If I interpret your question correctly (your English is better than my German), you can not get your '51 with a DG200 automatic transmission to back up/reverse. If this is the case, the most likely things are; 1) fluid level is low (check it per the owner's or shop manual), 2) your shift linkage is out of adjustment, 3) there is a blown out section in the gasket in the control valve assembly (most likely) or 4) you have a band problem.
