Rear Quarter/Body Panels
  • Rear Quarter/Body Panels
    Hi again,
    Can someone tell me how readily available body panels are for a 63 Hawk? I know.. I know..but I can't help entertaining the idea that I might keep/get stuck with it.
    http://cgi.ebay.com/ebaymotors/Stude...QQcmdZViewItem
    I've seen Phantom advertizing fiberglass replacements. The pictures I've seen look very good. If I know Rene (the owner of Phantom), they're probably as close to a perfect match for the originals as you'll find. If you want steel, I'm sure they're out there, but NOS ones will be hard to find and $$$.
      You keep going, and you're going to wind up loving that car
      quote:Originally posted by MacMyers
      Hi again,
      ________________________
      Mark Anderson
      1965 Cruiser
      http://home.alltel.net/anderm
        One side goes for $300, the other side is much more.
        64 R2 4 speed Challenger
        63 R2 4 speed GT Hawk
        63 Daytona Convert.
        JDP Maryland
          The fender you found will NOT fit your Hawk. The GT Hawks used a bit
          of a modified rear fender, in that the rear edge at the top stayed
          "flat" all the way to the end, instead of the earlier type which had
          a downward curve at top. The top chrome strip blends into the tail
          light on the GT, where the two are separate on the earlier models. If
          the fender is not DAMAGED from an accident, its cheaper to have a shop
          weld in new metal then replace the whole fender. I went to an actual
          welding shop (not a body shop) and it was CONSIDERABLY cheaper.
          Tom
          1963 Studebaker Avanti, 102,000, custom made brake brackets to mount 1998 Mustang GT 4 wheel disc brakes (soon to get 13" Cobra front brakes, 2003 Mustang Cobra 17" wheels, GM altenator, will be getting : 97 Camaro Z28 tan leather seats, 97 Camaro Z28 T-56 6-speed trans, Ported 'R3' style Avanti heads with stainless full flow valves, 'R3' 276 duration cam w/chrysler solid lifters, shortened push rods, aluminum cam gear, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires, waiting in the garage.
            Any decent body shop could use these panels for your car.
            I'd buy them just to have around,if you know you need rear quarters.
            Judging from the pics of your car,IIRC,you don't need them.[unless you've actually gotten that far as to grind or strip them to bare metal already]
            Did you get it running yet????
            LaSalle,Il
            61Hawk
            60Lark
            Oglesby,Il.
              No, haven't tried yet. It's evidence in the Quincy PD Investigation so I CAN'T do anything to it. I didn't think of that part when I decided to say an official Hello to my good friend Larry Brown. Now I want to start working on it and I can't. I'm not going to get any money from the PD thing... I just did it for revenge. I'm going to file a civil suit to get a judgment against the fellow.... but now I don't care about the civil suit anymore (Wife DOES)...I just wanna work on the car. I got some parts, some time, and a little money (very little). I'm tired of sitting in the car making zoom zoom noises.
              Mac
              LaSalle,Il
              61Hawk
              60Lark
                Oh yeah... I meant to ask... is metal that stuff the bondo is attached to?
                LaSalle,Il
                61Hawk
                60Lark
