Changing an open diff to TT
  • Changing an open diff to TT
    I am in the process of putting a Twin Traction diff in an open rear (both are Dana 44s). Anything specific I need to watch for. I know about the additional lubricant, but anyting else? Also, anyone know where I can get one of those TT diff tags?
    Dan White
    64 R1 GT
    64 R2 GT
    Dan White
    If you referring to the decal for service personnel, S-I and other vendors sell them.
    63 Avanti R1 2788
    1914 Stutz Bearcat
    (George Barris replica)
    Washington State
    63 Avanti R1 2788
    1914 Stutz Bearcat
    Washington State
      Have you got the axle shaft thrust blocks you'll need?
      If you're talking about the T tag, I might have one around here. They also have a decal that the vendors have that goes on the rear cover. It warns to use the proper fluid.
        Have you checked to be sure you have the correct TT unit? The 3.73 and lower ratio numbers are different than the 3.92 and higher numbers. If I remember correctly, the higher number carrier and TT units are about .220" thicker. Just check your TT unit to the carrier you're taking out to see that the ring gear pad heights are the same.
        Ted
        Dan White
        64 R1 GT
        64 R2 GT
          Mr. Biggs, it looks like I am missing the axle shaft thrust blocks. I am assuming that anyone that works on rears/trans might have these or ??? The tag is the metal tag on the rear cover that tells you what the ratio is and to use the special lube.
          Ted, I am changing from a 3:73 open to a 3:31 TT so I should be OK.
          Thanks
          Dan White
          64 R1 GT
          64 R2 GT
          Dan White
          64 R1 GT
          64 R2 GT
          58 C Cab
          57 Broadmoor (Marvin)
            From what I know, the thrust blocks aren't plentiful, but with some searching, you should be able to come up with a couple.[:I]
              This is much more involved then simply bolting the carrier into the housing. You must set up the gears per the shop manual or good gear setup procedures. Some special tools are involved, a case spreader is called for, I've seen some real creative guys do it without but its a challenge. The runout and backlash is set by shims under bearings. Damage to the bearing is possible if you don't have the correct pullers. Unless your wanting to learn and do some of these in the future I'd suggest you take your housing to some who set these up for a living. jeep scout etc use the dana 44. a good 4wheel drive shop would be your best bet. the average mech doesn't do enough of these to become good @ it. Rearend setup isn't something you want to get close on or take short cuts.
              Russ (
              Dan White
              64 R1 GT
              64 R2 GT
              57 SH (project)
              60 Lark VIII 2dr sd (driver)
              53 2R6 289 5SpdOD (driver)
              57 SH (project)
                Thanks for the info Russ. I am aware of the requirements and had planned to take the rear to a shop that specializes in diff, 4wd and various other driveline requirements.
                Dan White
                64 R1 GT
                64 R2 GT
                Dan White
                64 R1 GT
                64 R2 GT
                58 C Cab
                  Wise man you are!! Parts even for stude rears are readily available.
                  I got my last rebuilt kit from Randy Ring&Pinion. All they needed was #'s off the ring gear, they were able to get all the info from that.
                  Here's their site
                  http://www.ringpinion.com/
                  Dan White
                  64 R1 GT
                  64 R2 GT
                  57 SH (project)
                  57 SH (project)
