'46 Studebaker Pickup
  • '46 Studebaker Pickup
    A friend has a '46 M pickup, and wants to put it on a more
    contemporary frame...any suggestions?
    I know the S-10 frame works on the 49 and up trucks, not sure about the M series.
    64 R2 4 speed Challenger
    63 R2 4 speed GT Hawk
    63 Daytona Convert.
    JDP Maryland
      Yep, don't do it. Talk to Heidt's or Total Cost Involved and they can set him up with an independent suspension kit (uses Mustang II style front end). Unless he's talking a huge power increase, the original frame should work great.
      Tom - Lakeland, FL
      1964 Studebaker Daytona
      Michigan Speed - www.michiganspeed.com
      Club Hot Rod - www.clubhotrod.com
      LS1 Tech - www.ls1tech.com
      Tom - Bradenton, FL
        He's thinking he could have modern brakes.....etc, would like to make it
        a daily driver for a commute....
          I have been told that the S-10 frame will work. with that said, I agree with Swifster. The original frame is tough. I have a Fatman's Mustang II conversion under my 1947 M, a 10-bolt GM rear axle, and a MasterPower power brake setup under the floor. When I bought it, it had a Olds V8 installed by an idiot in it. I repaired the damage and replaced that with a Studebaker 259 V8 rebuilt with recommendations from Ted Harbit. The truck is peppy, handles well, stops well, and runs down the freeway with no problems.
          As far as I know, Fatman is the only company that makes a kit specifically for the M truck, but I'm sure Heidt's or Total Cost Involved kits can be adapted, and both are quality.
          Hope this helps
          jj
            his next question was going to be whether or not a V8 will work with
            the original frame, and it sounds as if that won't be a problem
            ....about what is the cost of the conversion to the Mustang II?...this
            sounds like the best way to update the undercarriage in a way the makes
            the truck an option for his 50 mile a day commute....
