Avanti Trunk Release Problem
  • Avanti Trunk Release Problem
    I would use some penetrating oil like "PB Blaster", remove the cable
    from the latch (not really a "lock"), and spray the penetrating oil
    down the cable from the latch end. Have someone keep working the
    cable in and out after you feel you have some down the cable. Spray
    some on the latch as well. WD-40 isnt much of a lubricant, and its
    not the best at penetrating tight or rusty areas. PB Blaster is an
    oil, and will help to lube the cable for the future. There is also
    some oil made for speedometer cables, you could run some of that down
    the cable after you free it up with the PB Blaster.
    Tom
    1963 Studebaker Avanti, 102,000, custom made brake brackets to mount 1998 Mustang GT 4 wheel disc brakes (soon to get 13" Cobra front brakes, 2003 Mustang Cobra 17" wheels, GM altenator, will be getting : 97 Camaro Z28 tan leather seats, 97 Camaro Z28 T-56 6-speed trans, Ported 'R3' style Avanti heads with stainless full flow valves, 'R3' 276 duration cam w/chrysler solid lifters, shortened push rods, aluminum cam gear, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires, waiting in the garage.
