Flex plate nuts?
  • Flex plate nuts?
    When I took my engine apart, the old flex plate was held on with castellated nuts:
    Reading the parts manual, what's specified is "Lock Nut - 3/8" x 24." Can I just use plain 3/8" nuts with lock washers, or do I need to hunt down something esoteric?
    Clark in San Diego
    '63 F2/Lark Standard
    They LOOK castellated, but they're actually self-locking nuts. The "castled" part is crimped ever-so-slightly to effect a grip on the threads. I'd find something similar. They make self-locking nuts without those cuts or fibre or plastic inserts. Shouldn't be TOO hard to find.
    Miscreant adrift in
    the BerStuda Triangle
      You most likely want a grade 8 self locking all steel nut. I wouldnt
      use a nylock due to the heat it will be exposed too. Napa carries a
      wide selection of nuts and bolts at most their stores. The one you
      are looking for will look like a regular nut, but be rounded & crushed
      on one side. If you look at the threads on the crushed side you will
      see that the threads are closed in a little. I used this type on my
      700 R4 conversion in the hawk some years ago, and when I removed the
      GM flexplate off the Stude crank - they were snug as a bug in a rug.
      Tom
        They are actually called "deformed locknuts" and are oval to max 40% of the nut height (if my memory serves me correctly). It is sometimes possible to see the imprints from the jaws used to squash.
        I seem to recall they should not be re-used, just as for the nyloc variety.
        /H
          Here's what I got from NAPA. Doesn't look like the originals, but they swear it will work. Will this do the trick?
          Clark in San Diego
            That'll do it!
            Miscreant adrift in
              showbizkid, thats the one I was trying to describe - did I come close?[:I]
              Tom
                Yeah, Tom! Looks just like what you described. Funny - when I went into NAPA, I told the counterkid that I wanted "3/8-inch-24 deformed steel lock nuts." He went and found 'em, and then he asked me "why are they called deformed steel lock nuts?" So I told him it was because the nut was actually deformed by pressure to form the lock.
                He looked at me and said "Oh. We just call 'em lock nuts." [)]
                Clark in San Diego
