Tachometer Installation
  • Tachometer Installation
    Recently in a thread about clocks someone threw out the comment that they changed out their clock for a tach. I might be interested in doing that, I'm just wondering how to go about doing it. The main question I have is where the tach hooks up to the engine to report the revs.
    Thanks.
    Rich Pease
    Ogden, UT
    59 Lark 2dr
    61 Lark 4dr
    Thanks.
    Rich Pease
    Ogden, UT
    59 Lark 2dr
    61 Lark 4dr
    A modern tack would hook up to the distributor side of the coil.
    -Dick-
    Bellingham, WA
      Studebaker Tachs are a bit more complex if you are talking stock.63-64 Lark tachs wire to a sender, then to the engine. Budget around $300-$400 if you can find the parts needed. BTW, the wiring is different on the Avanti powered cars, as is the sender.
      64 R2 4 speed Challenger
      63 R2 4 speed GT Hawk
      63 Daytona Convert.
      JDP Maryland
        If I do it, I'd use a modern tach. I saw quite a few at AutoZone that have the white face and black lettering that would be a close match for the stock gauges. So if I undertsand this right, I'd run the wire to the coil on the distributor side and I'm guessing it would be fairly obvious where it connects?
        Rich Pease
        Ogden, UT
        59 Lark 2dr
        61 Lark 4dr
          Rich Pease
          Ogden, UT
          59 Lark 2dr
          61 Lark 4dr
          I'm sure a new tach will come with instructions, but one wire will go to the small terminal on the coil that currently has the lead that goes to the distributor. You'll have other wires comming out of the tach. One will go to ground. One to the ignition switch, and one to the dash light switch/dimmer.
          -Dick-
          Bellingham, WA
            In that clock thread, I posted about putting a tach in a clock delete housing (64 Lark-type). I didn't post the picture right, but I can e-mail it to you if you want to see it. Dick is right about the wiring, as the tach I used had a color coded harness and instructions, and it was a snap. The illumination bulbs were hard wired, so I just colored them with a red Magic Marker.
            MarkC, 64 Y8
            Working in Spokane, WA
              Mark,
              Would you send me a pic, I'd like to see how it turned out.
              Thanks.
              Rich
              Rich Pease
              Ogden, UT
              59 Lark 2dr
              61 Lark 4dr
