Ground Cable
  • Ground Cable
    62 GT Hawk - Grounding strap is connected where on the right front fender? Parts book says 22 inch strap - no location - open hole adjacent on the fire wall on the right side facing up - prior non-stock strap bolted to battery shelf support bracket, then the middle bolt of the intake manfold. Battery has positive to front - negative to firewall - not sure that is correct.
    Thanks[8]
    The ground strap is only a few inches long. it goes from a bolt on the right motor to the frame mount. The negetive battery cable hooks to the top, outer water pump stud.
    64 GT Hawk
    64 R2 4 speed Challenger
    63 R2 4 speed GT Hawk
    53 Street rod
    JDP Maryland
      Here's a pix
      64 GT Hawk
      53 Street rod
      JDP Maryland
        Now thats one nice engine compartment n motor.
          Thanks[8]
          The ground strap from the battery should go to the engine (water pump stud/bolt), not the body sheet metal. Your battery is either the incorrect model or is in incorrectly. The negative , ground terminal should be towards the front of the car and towards the center of the car. If you can't achieve this configuration, you probably have a 24F (Ford style) rather than a 24 or 24C battery (that you should have).
            All I could see is a big orange air stuffer![:0] Nice.
