help
  • help
    i have a 57 champion 2dr that has a locked up 6 i want to put a inline 6 in will a ford or chevy bolt to the trans or do i need a trans for it
    Repeat answer for the same question in another thread by you:
    "Nothing brand X will bolt in and would not be worth the effort if it could. First choice, buy a Studebaker V8 parts car for a few $100 and move everything over. Second choice, buy a brand X parts car and do the same at a lot more expense and labor.
    One of the big adavantages in the Stude parts car option other then cost and labor is that you'll be able to add the V8 brakes and the rest."
    64 GT Hawk
    64 R2 4 speed Challenger
    63 R2 4 speed GT Hawk
    53 Street rod
    JDP Maryland
      Wouldn't a McKinnon 6 from a 65 or 66 Stude fit without much modification? They bolted up to the Stude transmission, but I have no idea what would be involved. He does say he wants to replace it with an inline 6 instead of a V8.
      ________________________
      Mark Anderson
      1965 Cruiser
      http://home.alltel.net/anderm
        The tranny has a different main shaft and the clutch linkage would need to be fabbed up.
        64 GT Hawk
        53 Street rod
        JDP Maryland
          Motor mounts are different on a 65-66 Studes than on the 57, the 57 mounts are 1 1/2" higher and further back. You would have to remove all the rivits from the mounts and put later frame brackets in the other holes. Another fun job.
            The '57s were the last year for the 2-piece driveshaft as well. Another thing to consider as far as an engine swap goes.[8D]
            Bill, you might run into an issue of the engine compartment being to short for a Brand X 6 to go in there. The Champion 6 (your's should be 185cu.in. version) is fairly short as was their V8. Other 6s were l o n g e r and may have clearance problems.
            Either way you go - even if you put a small block Chebby in it - you're gonna have numerous little things that you'll have to engineer such as throttle linkage, wiring, mounts, radiator compatability, etc., etc.. All do-able no doubt. But none if it will be "bolt-in" easy.[}]
              I've always thought it'd be cool to put an overhead six in Dad's '57 Pelham- seems like this would be the same thing- but I haven't done it yet, so I can offer no advice one way or the other. My brother made it look easy enough to put a 400 SBC w/700R in his '59 Lark, but that's a whole 'nother story!!!
              [8D]
              StudeDave
              San Diego, Ca
              '54 Commander 4dr
              '57 Parkview (it's a 2dr wagon...)
              '57 Commander 2dr
              '57 Champion 2dr
              StudeDave '57
              US Navy (retired)
              SDC Member since 1985
              past President
              Whatcom County Chapter SDC
              San Diego Chapter SDC
              past Vice President
              North Florida Chapter SDC
                Bill,
                You could easily enough find another Champion six engine to put in your car (although it may be an older, 170 cu. in. version which may or may not have had its displacement increased by a rebuild).
                Here is a rebuilt one that sold for $250 on eBay recently:
                http://cgi.ebay.com/ebaymotors/Stude...99882068QQrdZ1
                And here is one for sale now, which may not fetch the starting bid of $500:
                http://cgi.ebay.com/ebaymotors/1951-...spagenameZWDVW
                As for me, I recently bought one for $70, that's the same year as the original one in my truck. It's being rebuilt for me by GPO Automotive Machine Shop in Cheyenne, Wyoming. They say they have rebuilt approx. 25 Studebaker motors in the last year, 5 of them Champion sixes.
                1955 1/2 Ton Pickup
                Paul Simpson
                "DilloCrafter"
                1955 1/2 Ton Pickup
                The Red-Headed Amazon
                Deep in the heart of Texas
                  If this is the car in question~~~
                  http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
                  I'd find a Stude 6, or do a V8 conversion! It's already been 'played with', so a change under the hood wouldn't be bad either! For the record- the roof gives it away as a '58 Scotsman- or Champion w/o fins- it has '57 tail lights and grille, and late model wheels with '64/5ish hubcaps. Looks like a fun ride to play with some more- GOT FINS?
                  [8D]
                  StudeDave
                  San Diego, Ca
                  '54 Commander 4dr
                  '57 Commander 2dr
                  '57 Champion 2dr
                  StudeDave '57
                  US Navy (retired)
                  past President
                  past Vice President
