disc brake cylinders
  • disc brake cylinders
    do one of the vendors have replacement
    pins that go in the cylinder ?
    the pin that is in the center of casting extending thru the piston.
    I seam to be missing a couple of them
    thanks everybody.
    steve strait
    I doubt that you will find one of the regular vendors that will sell that item as all of them that I know sell the cylinders as a rebuilt or new unit. To find a component part of one of those units you'd have to figure out who does the rebuilding for the vendors. If I was going to do that, the first person I would contact would be Dave Thebeault. Good luck.
    Tim K.
    Tim K.
    \'64 R2 GT Hawk
      Maybe someone else has an opinion about this, but.... Those pins may not even be necessary. All they effect is a sort of self-adjusting feature. I don't know of another caliper that uses such an arrangement (after all, it IS a British design! [xx(])
      I can't see how the piston can drift back even without this pin/gripper thing. If your rotors wobble so much that they force the pistons/pads back, you's got more troubles than excessive piston travel![:0][V]
