Cowl Seal
  • Cowl Seal
    Does anyone know the corrrect way to install the cowl seal on a 53 Stude. it has a bulge in it that I'm not sure about. Does it go toward the front or rear of the car? I don't remember how the original was when I removed it. Thanks,
    Darryl C. Lewallen
    There are 2 bulges in the seal a small one to the front the larger one in the back and there are 2 rivits one on each end.
      Thanks alot for the information Alan
      Darryl C. Lewallen
      Darryl C. Lewallen Clarkesville, Ga.
        On my Speedster, there is a large, square, flat rubber seal that has a bulge and hole for the steering column to run through. Does the bulge go toward the interior or towards the engine compartment?
        James D. Wilkerson
          Towards the interior. There should be some ribbed lines on that same side.
            Thank you, Mr.Biggs! Does this seal go over or under the firewall insulator? or is there a cut-out in the firewall insulator? I'm trying to figure out what should show on the engine compartment side of this seal?
            James D. Wilkerson
              The insulator is under the seal. From the engine side you will see the bare insulator fibre material.
              On a related topic, I have seen a '53 sedan in a old 'yard w/o the optional defroster and the hole in the firewall where the blower motor normally sticks through did not even have a blockoff plate to cover it, the fibre insulator material was visible and all that covered the hole.
              '53 Champion Hardtop
              Jeff in ND
