Ford V8 engine swap
  • Ford V8 engine swap
    Any one swap a Ford V8 (302ci) into a early Lark VIII(59-60)? How diffucult is it?
    I'm sure there's some reason you're contemplating this.
    This is your first post so, give us some background on your situation before we get in to the nitty gritty.
    Brad Johnson,
    '56 Sky Hawk in process
      Depends..
      Front mount oil pan sump can be a pita...
      All the mounts need to be built..
      Custom exhaust too...
      Lot's of work to save a hundred pounds or so...
      DEEPNHOCK at Cox.net
      '37 Coupe Express
      '37 Coupe Express Trailer
      '61 Hawk
        Consider a 289 instead of a 302 and really confuse the hell outa them <g>.
        -Dick-
        Bellingham, WA
          Sorry, I must confess, Iam a redneck,,, In the land of Studedome, We just dont get overly excited about Fords and Chevys especially mated up to Studebaker Rare Earth cars. It really chokes us up. Let us help you locate a nice 259 or 289 and help the cause. Tom
            I also must confess I would love to go the easy route and keep it stude but that would just rub everyone from the "keep it originals" to the "modify it till it blows up". I have a early Lark with a dead 259 w 3sp OD trans. I also happen to have a newly rebuilt Ford(sorry guys) 302. Just wondering if anyone has done this swap and how much fun it would be. I am aware of the Chevy (sorry, again) swap on the C/K bodies.
            Yes, I am aware that just mentioning this abomination is driving many of you insane! Just deal, or help me find a reasonable priced running 259/289 around Northern Colorado.
            Thanks in adavance for the info.
              Not me. I can help if it was a Chevy swap you were contemplating, but no experience with a Ford. A Ford motor is bigger (longer) than a SBC Chevy, but should still fit. Jeff's caution on the Ford front sump is a good one if you are sticking with the stock Stude steering.
              http://pg.photos.yahoo.com/ph/ddstnk...12.jpg&.src=ph
              -Dick-
              Bellingham, WA
                Just what exactly is wrong with your "dead" 259? Just about anything except a cracked block can be fixed, and a lot cheaper and easier than the ferd transplant you are contemplating. If you want power, the Stude can be built to run with the best of them. Your car, your choice. I've never had much luck with those weak-valve ferds. Also, my favorite transmission is a three speed with overdrive behind a Stude V8 - equivalent to a 5 speed, and strong as whiskey breath! If you do persist, keep a log and document it with photos so the rest of us can watch your progress, OK?
                  It will fit with a Bronco oil pan but how you position it it will be very close to the stearing bell crank.
                    Can you still get parts for those fords???
                    Home of the Almostahawk
                    Oglesby,Il.
                      Hee - hee - hee - hee .......[)] Good one 52Hawk!
                      Wonder what's happened to dimples and her '52! [?]
                        Yep,re-build what you have or find another Stude V-8 is the way to go. Way less problems,and a much better engine,must be one near you if yours froze up and cracked or something.
                        Im not against mods,I just like Stude V-8's ,and Ive had only one Ford 302 in my life. I know Ford has sold a zillion of them and lots of folk must be happy, but that engine (in a pick-up) was the worst gas guzzling, gutless POS I had experienced since the 305 Chev.
                        It finally broke its timing chain one cold winter morning and I put the thing out of its misery.
                          While not much of a Ford guy....."put it in".
                          I have no idea what the parts may cost, but there ARE parts out there to make your small block Ford a rear sump oil system. I know this because a friend finally is installing a sb-Ford (302) he bought parts a long while ago for a swap into a 47 Ford. Same problem, front mounted crossmember. So there are parts for your desired configuration out there.
                          It's [u]your</u> car, [u]you</u> have to be happy with it in the end. I say do it and have fun.
                            stud_s,
                            I assumed from your first post you must be sitting on a good DORF engine with no body and a Stude body needing an engine.
                            As you can tell, so far, there's not a lot of experience with DORF swaps though I expect it's been done. The GM swap is so much easier but that doesn't address your situation.
                            Change your oil sump, sit the engine in on blocks or jacks where it won't interfer with steering, radiator, suspension, hood, firewall, etc., mock-up mounts and crossmembers, fabricate mounts and crossmembers, fabricate shift linkages, fabricate throttle linkages, fabricate driveshaft, fabricate, fabricate, fabricate. Expect some cursing, gnashing of teeth and pulling of hair.
                            Keep a record and keep us informed. Someone will benefit from your experience. It will probably be less expensive to fix or replace your 259 and you can use the money you save to find a solid 55 Ford pickup that would love to have that 302 under the hood.
                            Someone who has already done the swap you propose may yet respond. And if anyone asks why you did it you can say "I did it on a Lark!"
                            Brad Johnson,
                              I did it about 20 years ago with a Bronco pan, but they might be hard to find now, you might check the late Fox body pans with the rear sump 1985-94 Mustangs, to see if you could make that work. It is a nice instalation that can get you in the high 12's.
