Wiper motor wires
  • Wiper motor wires
    Gang - I bought a new 12v Prestolite wiper motor from Dennis when I was in SB a few weeks ago, and want to use it in my 12v '51 coupe. I'm trying to use the 4 spade connector wiper switch from a '60 dash, and can't seem to find a manual that explains where the red, blue, yellow and black wires go from the motor assembly. (I believe it's for a '63 or '64 application, originally)
    I assumed the red was 'hot' and black was ground. I don't think so. Anybody know fer sure? Thanks!
    I found the info in the '65 shop manual supplement.
    Wire 38A (blue) Wiper motor park switch to wiper switch A terminal
    Wire 38B (black) wiper motor park switch to wiper switch B terminal
    Wire 39A (yellow) wiper motor low speed armature to wiper switch D terminal
    Wire 39B (red) wiper motor high speed armature to wiper switch C terminal
    The earlier '59-'64 shop manual doesn't list these wires and colors.
    Good luck, Tom!
    Gary Ash
    Dartmouth, MA
    '48 M5
    '65 Wagonaire Commander
    '63 Wagonaire Standard
    www.studegarage.com
    Gary Ash
    Dartmouth, Mass.
    ’41 Commander Land Cruiser
    '48 M5
      Thanks much, Gary!
        TOM- I WENT THROUGH THE SAME PROCESS ON MY '52 COMMANDER LAST YEAR. I ENDED UP REUSING THE ORIGINAL SWITCH, BUT HAD TO RE-SOLDER THE GROUND POST. THE SWITCH "GROUNDED" THE CONNECTION, WHEREAS LATER SWITCHES CLOSED THE CONNECTION TO THE "HOT" LEAD. I THINK A LATER 12V TOP OF DASH SWITCH MAY FIT, HOWEVER I COULDN'T FIND AN AFTER-MARKET 2SPEED SWITCH THAT WOULD FIT UP IN THERE. HENCE NOW I HAVE 12V, BUT SINGLE SPEED, WIPERS!
        BRUCE IN YAKIMA
