Bad voltage regulator?
  • Bad voltage regulator?
    I'm wondering if flickering headlights with accompanying flicks on the ammeter usually indicate a bad voltage regulator. My '64 Daytona had those symptoms and my '66 Cruiser does too - and fairly badly to start off with.
    I've never replaced these things. It looks easy enough, but I just wondered if it's a common thing to go bad. Maybe they just get really dirty and corroded after 40+ years.
    It may well be the regulator. If so, replace it with a solid state version used on late 60's Chrysler products.
    64 R2 4 speed Challenger (Plain Wrapper)
    63 R2 4 speed GT Hawk
    JDP Maryland
      JDP, that sounds like a good idea. I have been told, though, that the Chrysler units have 2 wires coming out of them, whereas the regular ones Studebaker used have 4 wires. How is the two wire version supposed to replace the older 4 wire version?
        Could very well be the voltage regulator -- they go bad when the points wear
        or get dirty and get out of adjustment. The original ones can be repaired, but it's
        not worth the trouble to fiddle them into correct behavior. An original unit would
        almost certainly be shot by now.
        Note that what you describe -- flickering headlights and ammeter -- could also be a
        short somewhere in the harness. That is a very likely scenario, too. Does the
        ammeter go to high current draw or to low current draw when it flickers? Could be
        a short to ground or a flaky connection in the headlight circuit.
        It's a nuisance tracking down electrical problems.
          First thing to look for is a bad ground. On the Chrysler the 2 wires go to the regulator, the regulator grounds one wire so current flows through the field so that it charges.
            Check the requirements of your headlights aswell, and like Alan said check the ground circuit real good. In the past I have had to install a relay cicuit breaker of higher value, and this solved the problem. You may have an alternator thats on the way out, or bad battery. Load test the charging system first, then go from there. Sometimes circuits get messed with by owners and I have found overload issues quite often due to bad sterio installs and other accessories. Its a good Idea to check to make sure that someone has not butchered your fuse panel or spliced into places that could cause problems. Ground circuits seem to take real abuse at times. The chrysler charging method is a good recomendation, I have used it in alot of my engine swaps due to its simplicity, and quite reliable., Tom.
              Well, of course everything in this car is suspect, but I think the wiring is probably OK. The ammeter never gets much below the center line at any time when the flickering occurs and it is very regular - say about a flicker every half second. If it was a short, even an intermittent one, I would expect less regularity.
                You realy didn't say as to weather you had a electronic regulator or a relay type regulator but it sounds like a bad ground the electronic regulator grounds through the case and the relay type does too. The fluttering could be the relay kicking in and out because of bad ground.
                  Right on Alan, Tom.
                    Hmmm... OK. I hate checking for grounds, but a guy's gotta do what a guy's gotta do.
                    It is the old mechanical relay type. If I put a new solid state one in and the ground is not good somewhere else could I damage the new unit?
                      4 wire ?, is it a Avanti ? If so, Dave T Bow sells a solid state version.
                      64 GT Hawk
                      53 Street rod
                      JDP Maryland
                        Yes you can damage it. Motorolla does not like to dead end. Tom.
