points or electronic ignition
  • points or electronic ignition
    im wanting to replace the points in my 50 champ
    where can i get these at saco or where or can they be purchased at my F.L.A.P.S.
    also should i just drop that idea and switch it over to electronic ignition and where can i get the kit
    oh yeah one last thing
    i never have evan opened the dist cap on my car
    how hard are these point to install
    ive change lots of old ford and chevy points but dont evan have the faintest idea whats under the cap on a stude
    im one of these if it works leave it alone people but im getting some difficulty starting and some hesitation
    my dad (an ol school hot rod shade tree) says clean the points
    well screw that if im gonna do it why not do it right and either replace them or upgrade
    Probably easier to pull the distributor and work on it while it's clamped in a bench vice. Just make sure to put it back in the way it came out (might want to put it to #1 TDC just to make sure before you pull it) that way if you drop any screws you can just turn it upside down and start over, and you're not leaning over the fender while you're working
    I don't know if any 6V electronic ignitions are available...
    62 Daytona hardtop
      the six volt is not a problem
      the cars been convert to twelve volt already
        For electronic conversion(like Pertronix) check with Cathcart(www.studebakervendors.com) or Dave T-bow has new Champion distribs for 12 volt applications.(see ad in TW)
