Chevy engine mount location??
  • Chevy engine mount location??
    Hello all, I am getting ready to drop a chevy v8 in my 62 Lark. I have the frame mount adapters from a 65-66. Where exactally would these bolt up? I know the general area, but there is several holes drilled there..Are 3 of these the corrcet ones, or do it need to re-drill to get these in? Also, as far as motor mounts, is there a generic chevy car to use them from Camaro etc? Thanks!!
    Those mount brackets should line up with 3 of the existing holes on each side of the cross-member. It's a bit of a bit*h to get the nuts on inside that crossmember. Make damned sure you use self-locking nuts.
      Mr. Biggs, thanks!! There are more than 3 holes..are there only three that will line up correctly? Thanks again!!
        Yes - only three that will work and end up with the mounts oriented correctly.
