another electric pump question
  • another electric pump question
    I converted my Lark over to electric fuel pump recently. I used a Facet pump that runs up to 10 PSI. It seemed to work OK the first few times the car ran then I let the car sit for a week or so and it would not restart. I looked through the carb and there seems to be a puddle of gas sitting in the manifold. The original fuel pump specs read 3.5 to 5 psi so I am thinking that the pump is too strong and overriding the float system and pushing the needle valve back and dumping gas through the carb. I plan to get a 5 psi regulator and see if that fixes it. Have any of you had the same problems and does this prognosis sound accurate? The oil smells a little gassy so I need to change that too.
    I have the stock 170 ci with single barrel carb.
    Paul Leske
    '59 Lark VI
    Sounds like you got your finger on the problem, too much pressure. By all means, change the oil, before you start or drive the Lark again.
      sorry this doesn't solve your problem, but i have an electric fuel pump too and i am wondering what you used for a blanking plate when you took out the mechanical pump?
      slow64
      1964 lark daytona
      bd_marks@yahoo.com
        Too much pressure. Get an inline pressure regulator that's adjustable. Local auto parts store should have one. Set it at 3& 1/2lbs.
        The blanking plate should be available from any speed shop. That pump opening was the same shape and hole placement on MANY BrandX engines, including Chevy, I believe.
          Actually I left the (not so old) mechanical pump on the engine and I just hooked it back up today. I disconnected the electric pump and left it mounted. It is getting cooler out (less risk of vapor lock)now and the $75 they wanted for a pressure regulator was too much for me to stomach today. I found a crimp in the gas line and I fixed that and probably wont need the electric pump anyway. It is much cheaper to buy the pump with the proper psi rating than to have to regulate it. I learned the hard way. Now I have the pump that I can hook back up in 10 minutes if I ever blow the mechanical one on the road. I also found that I have less problems if I dont let the fuel level drop below 1/4 tank.
          So if you have too strong a pump it will push gas past your needle and seat and flood the carb. I personally would not use BOTH the mechanical pump and an electric one as some on this forum have done because I am worried that if the diaphragm breaks on the mechanical one then the electric one would push gas through the leak and into the engine.
          slow64
          1964 lark daytona
          bd_marks@yahoo.com
          Paul Leske
          '59 Lark VI
            I just bought a Airtex pump model e8011 that you can put in line and the mechanical pump will pull right thru it. You could hook up with a push button and just us it when needed!
              I think this electric pump thing was in the Cooperator [Turning Wheels] within the last 2 years... Something like 3 different types of pump,but one can be used in conjunction with the stock mechanical pump. Mr Biggs- right on the gasket- same as SBC,and the thermostat housing gasket is also the same. The Chevy thermostat can be used in the Stude V-8,if you drill a 1/16 hole in it for venting.
              Home of the Almostahawk
              Oglesby,Il.
                $75.00 is excessive to pay for a pressure regulator. I have bought several inline regulators at local auto parts stores for less than $10.00.
