Hawk Power Steering
  • Hawk Power Steering
    I have a 63 Hawk R1, and just bought a power steering set up for it. Has anybody hooked one of these up before? IT appears simple and straight-forward enough, but that's what I thought about my ceiling fan!! Anything to watch out for?
    Thanks!
    Make sure you got a Hawk reach rod with that setup. Lark's are different. Also, make sure you get the hoses hooked up right. It's hell when you fire it up the first time and have the slave cylinder drive the wheels the opposite way that you turn them! Wham!
    I've seen it happen![xx(]
    Pay attention to the hoses clearing the exhaust manifold too. I wrapped the one's on my Lark with a flat, woven stuff (like asbestos, but it's not) that they use on boiler doors.
      Mr. Biggs is right about the hoses. Get the shop manual and make sure the right hoses go to the right holes. Also, I had much better luck with leaks when I started using a tube wrench(also called flare fitting wrench). Regular wrenches just won't get those fittings tight enough.
        Thanks for the advice... I will be careful with the hoses. I am prepping the parts now. One question that comes to mind, do I need to have a power steering column, or will my manual work?
          Your steering box is used for manual or PS. There's some differences for various models that use this Bendix setup, but not on any of the Hawks. You should be good-to-go in that department!
