need drum
  • need drum
    I've decided to leave the dana 44 under my 61 hawk.Does anyone have a good useable,turnable, used drum for sale???or a pair? I will need every thing from the wheel bearings out.The right rear was metal to metal for so long,it's almost cut the drum in two. Thanks!!!
    Hawks,Larks,and other critters!
    I've got the front drums off of my 62 Lark..Are they the same? I'm converting to turner brakes
      No, his rear drums are 10" Whereas your fronts (assuming this is a V8 car) are 11"[:I]
        Yes,this is a 61 Hawk,v-8 10" drum.[Thanks Mr biggs-I should have been a little more specific in the first place!]
        Oglesby,Il.
          Hey Mr. Biggs, wouldnt the 10"drums off the front of a six cylinder car work for his Hawk rear??
          Anyway 52 Hawk, have you tried Robert Kapetyn or Don Gay??
          They advertise in the TW from time to time and are in your neck of the woods.
            Yeah - they would swap. But as the prospective donor car is getting disc brakes, I assumed that IT was a V8 also. Hence, it should rightfully yield 11" drums.
            WHOOPS! Now I see in another post that prager's 62 IS a 6cylinder that's being convered to a V8! So what are ya gonna do for rear brakes prager? Stay with the little 9-inchers?
              Hello guys, yes the front drums are off of a 6 cyl model...are they the right ones?
                Mr. Biggs..sorry I should have read your entire post before I replied..oops!![:I] Anyhow..Turner brakes all the way around..Putting in an LT1 corvette 350 and a Tremec 5 speed..have all of the parts except the 65-66 stude to chevy frame mounts..would like to get them cheaper than SI wants!! Help!!!!
                  Yeah, the 10" drum should help 52Hawk so long as it hasn't already been turned too far. .060 oversize is the max allowable amount to turn them
                  He'll have to have the lug stud swedgings ground away and the studs pressed out of the hub/drum assy. This needs to be done carefully so as not to distort the drum.
                    Jon Meyers in Ohio has them for $85 a side.The Chev. Stude mounts that is.
                      I'll drive down to see Don Gay this weekend,and call or email Kapteyn[actually hadn't thought of him,don't know why?]-but,thought I might find some the easy way-sitting on my butt at the 'puter!!!Kapteyn can be a little high priced,but what a joy it is to visit his place,truly amazing-you might say: Worth the Price of admission!!! While I'm on the subject,any Stude nut should see Bob Kapteyn's place,it's as cool as SASCO,probably better.38,000 square feet of Stude cars and parts!
                      Prager,I'll keep you in mind,but it will be easier for me to find a rear,on a hub! Are those finned? my rears are finned.
                      Oglesby,Il.
                        6cyl drums wouldn't be finned. And you're right in that it would be alot less troube to find one already on a rear hub.
                        Geez, Kapteyn's place! I've always wanted to visit there![]
                          hey guys, no fins..Like Mr. Biggs said... sorry..You could try to call Tom Karkiewicz, in South Bend..he has a ton of Stude parts new and used..574-287-5834
                            Alan, can you buy just one side? (The mounts)..I have a lead on the left but no right..
                              Yes call Jon Meyer in Duncan Falls Ohio at 1-740-674-4897 the numbers are 1563714-15 Engine mount bracket 65-66 $85 each.These are for Avanti and Larks, for the 61 Hawk the number is diffrent but he has them too.
                              same price.
