Rear differential oil
  • Rear differential oil
    It is time to change the oil in my rear axle on my 1951 Commander. Last time I did it, I used straight 90 weight gear oil with no additives. Now, I go to the same store where I bought it the last time, and they don't have anything like that anymore! What they do have is 85-90 weight multi-vis with additives, 90-140 weight with additives, and some synthetic called "Mystic" that is rated as 85-110 multi-vis with a whole bunch of additives. I can keep looking, but what is the general consensus on rear axle oil? It is a type 23 4:55, the stock axle, and has never had anything but straight 90 weight dino squeezin's.
    90 wt (75W90 or 75W140) with additives not an issue in rear diff., issues have always been raised about other than GL-1 in OD trannys.
      Where does one get GL-1 oil?
        Most auto parts stores only sell GL-1 in 5 gallon pails, but TRACTOR SUPPLY sells it in gallons and AMSOIL sells it in quarts (http://www.oldcarfart.com)
