1949 Stude/ Sixbanger - Engine Oil
  • 1949 Stude/ Sixbanger - Engine Oil
    Hi folks,
    any recommendation of you which engine oil would be best to use in my '49 Stude with its Sixbanger?
    BR,
    Bjoern
    ____________________________________
    Livin' in Germany: 1949 Studebaker Champion Regal Deluxe Starlight Coupe
    Shell Rotella diesel oil, 10w 40 (I think).
    Mark Anderson
    http://home.alltel.net/anderm
    1965 Studebaker Cruiser
      It's usually 15W40 IIRC. Chevron Delo is very similar. Not sure what is available in Germany but what you're looking for is a "fleet" oil or one that is rated for use in both gasoline and Diesel engines. Reasoning behind this is that the Diesel rated oils generally have a higher level of detergents and anti-wear additives which may not be desirable for a modern engine with a catalytic converter, but can be beneficial for an older engine without a cat.
      62 Daytona hardtop
        I've been using Castroll 20W-50 in my '59 Lark VI with very good results.
        Rog
        '59 Lark VI Regal Hardtop
        Smithtown,NY
          Shell-Rotella 10-40 or Diesel-all. I've used it exclusively for years in both worn and rebuilt Studebakers.
