Fuel problem
  • Fuel problem
    My '50 Champion has all of a sudden developed what I believe to be a fuel problem. It may run twenty miles, or a few hundred feet, and then stop as though it has run out of fuel. After it stops running it is hard to restart. I added a in-line fuel filter about 600 miles ago and don't think that's the problem.
    Fuel pump, pick-up filter in the tank, vapor lock???
    Any help would be appreciated, I'm afraid to leave my garage at this point.
    Regards,
    Dick
    These are famous for vapor lock if your missing the fuel pump cover (sheetmetal)it protects the fuel pump from the exhaust manifold/block .they are often missing after fuel pump replacements thru the years
    My Studes:
    1.1947 Commander 14A-C3
    2.1948 Champion 2 door sedan (parts car)
    3.1948 Champion 2 door sedan
    4.1950 Champion 2 door sedan
    5.1959 Lark 2 door post
    6.1964 Stude challenger 2 door
      I had a Kaiser with similar simptoms...Pick up tube in the tank plugs, car sits and plug works loose, then a repeat of the same.
        Curts advice makes better sense than mine since the problem just started.
        My Studes:
          Regards,
          Dick
          http://RacingStudebakers.com
          Sonny
            I had a tank that went bad with rust floating everywhere shortly after I bought a Lark that had been stored for years but was in good condition. The tank went to pot and I bought a new one--nos from one of the Stude. suppliers. It was double the cost of using a coating repair system from a car parts store but it's done right. I filled three plastic see through filters with rust, ruined the fuel pump, and stalled repeatedly. New tank was the fix. Brad
