Spark plug wires
  • Spark plug wires
    I have a 1951 Commander that is still running 6 volt system and I want to replace the spark plug wires. Is there any advantage in keeping the solid copper wire over the newer type? I have installed a musical horn that works fine until I start the engine then I get alot of interference . I am running horn off of 2 6volt lantern batterys hooked in series so there is no conection to the charging system and I know the spark plug wires are bad.
    Brian Scott makes a nice set of V-8 wires; check with JDP or Ray Fichthorn, I know those two sell them. Perhaps some other vendors as well (SASCO?)
    62 Daytona hardtop
      I appreciate the input but I was wondering if there has been someone who has used the modern wire as oppossed to copper wire and pro & con of both. I can get both but not sure witch way yo go.
        Go with the modern wires. There's no real advantage to the copper ones unless you just like static in your radio.[xx(]
          Thank you very much. I have entered the Newport hill climb the last 3 years and have done well and I was not sure how well the new style wires work on the older cars.
