Carter AFB on '63 R2
  • #16
    Mike: Thanks a bunch for your recommendations. I do have Gundry's book--I just need to remember to refer to it from time to time. I just got off the phone to Summit and they have Edelbrock floats for a cheap price of $13. I may try and check mine first for leaks via Stan's procedure and then go on from there. As for the accelerator pump seal, what I have now is basically what Stan has done--namely two o-rings. Mine however might be a little smaller in cross sectional diameter than what he was able to use as he talks about having them compressed inside the "void" underneath the air horn cover and I don't think the ones I used actually fit that tight. Hopefully one or both of these areas will solve my problem. I'll get back to the forum with my progress as it unfolds. Thanks again.
    wagone/waygone in Iowa
    • #17
      wagone... yes these2-piece needles had separatepointed ends that came apart and caused my gas puking problem leave it to me to get something wierd. good luck
